oil change interval
Old Mar 23, 2021 | 07:53 PM
yellow2007's Avatar
yellow2007
Default oil change interval
Before I retired I was driving 100 miles a day 5 days a week. I would always hit the oil life percentage before coming close to the date on the sticker. Now I drive maybe 40 miles a week. I'm at 57% and the oil looks good but I'm coming up on the date.............which would you guys go by? Date or %?
Old Mar 23, 2021 | 07:55 PM
Elk's Avatar
Elk
Ignore the sticker. Follow the oil life monitor.
Old Mar 23, 2021 | 07:57 PM
Kevin A Jones's Avatar
Kevin A Jones
% as I have never put much stock in oil needing to be changed every 12 months.
Old Mar 23, 2021 | 08:05 PM
CLLOFF's Avatar
CLLOFF
even if you dont drive it the monitor will reduce by 1/12 each month. Its which ever comes first "wear" or 12 months.
Old Mar 23, 2021 | 09:11 PM
With the mileage you are expecting to put on the car, just go by the oil life monitor - it may hit the time limit before a mileage limit. Once you change the oil the next time, chances are you will bump up against the one year max between changes before you have to worry about the mileage.
Old Mar 23, 2021 | 11:08 PM
Skid Row Joe's Avatar
Skid Row Joe
I go by miles these days. I generally reset the oil monitor and ignore the date.
Old Mar 24, 2021 | 02:08 AM
HOXXOH's Avatar
HOXXOH
There's no expiration date on oil bottles, so follow the OLM and disregard the time stamp.
Old Mar 24, 2021 | 03:33 AM
Vette Jockey's Avatar
Vette Jockey
Roadster Madness. 😠
St. Jude Donor '13, '20-'21
How do you reset the oil monitor?
I had the oil changed and they did not reset it.
Old Mar 24, 2021 | 07:16 AM
Brunello's Avatar
Brunello
I go by my average yearly mileage. I drive my car on weekends which equals about 4-5k per year. Change the oil once a season. Synthetics are good for 10k miles so even at 5k is more than good under normal conditions. Easy to remember.
Old Mar 24, 2021 | 07:24 AM
Tom/99's Avatar
Tom/99
I go by the mileage, I ignore the OLM, and just reset it.
Old Mar 24, 2021 | 08:15 AM
Red08's Avatar
Red08
I change my oil once a year. I typically drive 3,000 to 5,000 miles per year. With those kind of miles, I don't even pay attention to the oil life monitor. I always change the oil/filter just prior to putting it to bed for the winter months.
Old Mar 24, 2021 | 08:22 AM
Kevin A Jones
Resetting the OLM is part of the C7 oil change process, unfortunately some dealers don't know that.
To reset your OLM, scroll down to oil life remaining on the DIC (Driver Information Center, left control on the steering wheel) and press and hold the Set/Reset button.
Old Mar 24, 2021 | 08:29 AM
baxsom's Avatar
baxsom
Change the oil, send a sample out to get analyzed. Follow their advice when you get the results back.
Old Mar 24, 2021 | 08:34 AM
yellow2007's Avatar
yellow2007
Thanks to all for the replies.......I think I'll follow the monitor and routinely check the oil.
Old Mar 24, 2021 | 08:52 AM
JMII's Avatar
JMII
Why do people ignore the OLM? The engineers programmed the computer to tell you when the oil needs to be replaced - it goes by combustion events and time. From Tadge: https://www.corvetteforum.com/forums...-wet-sump.html Not all miles are created equal so that is not a good system. The time factor is debatable but to keep your warranty you have to do it once a year per GM. An oil change costs about the same as two fill ups of gas... not exactly expensive on a car that costs over $60K. So easy to follow the OLM so that is what I do... I wish all my vehicles had this feature.
Old Mar 24, 2021 | 09:30 AM
Boiler_81's Avatar
Boiler_81
In the sealed bottle the oil is not exposed to oxygen. Just follow the OLM, simple. Don't over think this.
Old Mar 24, 2021 | 10:45 AM
62RPO582's Avatar
62RPO582
I drive less then a thousand miles a year and change my oil once a year like the owners manual says.
To oil change interval
Old Mar 24, 2021 | 12:13 PM
Skid Row Joe
You use the right side of the steering wheel controls to get to the oil meter. When it comes up, you just hold the button down and it resets. I could take and post photos of each step, if you can't get it reset. But it's simply running through the menus that appear to get to the oil meter.
Old Mar 24, 2021 | 12:22 PM
Skid Row Joe
They're good for way more than that. One test lab advised that at 15K, the tested100% synthetic was good for at least another 5K, and to resubmit a sample then. The only way to know if the oil is good or not is if you get it tested.
The year old oil in the crankcase, with 3K miles on it? Wonder if it tested bad?
Old Mar 24, 2021 | 07:24 PM
iclick's Avatar
iclick
The official line from Mobil 1 is that their oil is good five years after the time stamp in an unopened bottle.
