I have a 2019 GS and I picked up a nail yesterday. How do you repair the tire.??
I can't believe I had a C5 for 18 yrs and never a nail. Only have 4,000 on my 19 and I get a nail.
Suggestion on fixing it??
thanks
Fred
Patching is the way to go, depending on the location of the puncture... If it's on the flat of the tread it's normally repairable. If it's on the curve of the shoulder from tread to sidewall it is not repairable and the tire must be replaced...
Patch plug is the only way to go, plugs are never last.
I agree that a patch is the best way to go, but I have used plugs many times over the years and I have never had one fail...but they were used on non-run flat tires. I am not sure if that makes any difference?
"Unfortunately, when it's time to consider repair, even a trained tire specialist may be unable to confirm internal structure damage resulting from a run-flat tire having been driven in a severely underinflated or zero pressure conditions. Such damage may not be visible on the surfaces of the tire's exterior sidewalls or internal liner, making it impossible to determine tire suitability for repair or reuse. Because of this, Tire Rack and many tire manufactures recommend replacement of run-flat tires driven in a severely underinflated or zero pressure condition." (Flat tire repairs- after driving on run-flat tires. Tire Rack )
Note: Michelin repair policy= One repair maximum.
(Def Caveat: A warning or proviso of specific stipulation, conditions, or limitations.)
thanks
Fred
Fix a flat will plug the TMPS sensor. If it has not been driven flat pump it up and go to a tire shop for a patch if driven flat you will need a new tire
Many thanks,
Ray
AFAIK, there is no centralized system that keeps track of tire failures after repairs.
But so far I have not heard of any Corvette runflats that catastrophically failed after a proper repair (remove tire, inspect interior, patch from inside, remount tire).
Hopefully, OP didn't need to drive on a flat and won't have to worry about that aspect.
Patch plug is the only way to go, plugs just never last.
I did an external plug (cheapo Slime brand) on a ZO6 rear (Michelin PSS) and it never leaked for the next 6000 miles until the tire was replaced for wear. I would have preferred an internal plug patch, but didn't want to chance some Bozo damaging my wheel. (Don't know of a trustworthy shop close by.) Of course, being a run-flat, I didn't see much risk. My tire had not been driven in a low-pressure state.
thanks
Fred
thanks
Fred
Check with your dealer or large local tire dealer. I doubt you have any Discount Tire Stores on Long Island. As long as the tire doesn't have a puncture near a tire edge or hasn't been driven a long distance with no air it is repairable just once. Some dealers and stores won't repair them due to liability fears. However, some stores will repair them at no charge with no invoice. I see there are Mavis Tire Stores near you, They may be able and willing to patch/plug the tire.
Bill
Discount tire has patched 2 tires in the past (not on my C7 or C3) and didn't even charge me. I'm just not sure I would let DT touch my C7 due to past issues with my Truck... As I've said, " your DT experience will vary by location."
