My rear tires have good tread, but the fronts are getting worn. I do plan to replace them all as they are 6 years old. Would there be any concerns with doing the fronts and then the rears a few months later? The car is driven low mileage, so there will not be a significant amount of miles put on before the rear tires are replaced. Other than the time of taking them into the tire shop twice, are there any other issues to be aware of? Are the alignments done on the C7s all-wheel alignments?
Short answer is Yes.
Its almost always preferable to rotate the newest tires to the rear. But with staggered sizes on the Corvette that's not possible. There's no issue replacing either the fronts or the rears as needed. Only issue might be tire companies offering better deals when you buy all 4 tires .
You will require a 4 wheel alignment . Know that the Corvette , unlike most cars, also has a rear caster adjustment which cannot be done on any current alignment machines. It requires a special tool and a digital angle meter which many tire shops do not have. You would expect Chevy dealers would have the necessary tools and experience to do this, but many actually do not.
To be properly aligned you will have to find a dealer or shop that is experienced in doing alignment on C7 Corvettes or Porsches, which also has adjustable rear caster.
Good advice, thanks for that. Hey, I used to live in Jersey, where are you located in Central NJ? Or should I say --- what exit?
Exit 8A. Where you?
We considered moving to central florida when I retired but too hot for 9 months and Orlando is a crowded mess. Was looking at Winter Garden and Claremont area.
I just went through this dilemma yesterday, as my passenger side front was starting to show some cords, but the rears still have a good bit of life left in them. These tires aren't cheap in Canada so I don't like the idea of replacing them before their useful life is over.
I went with the Continental ExtremeContact DWS-06 Plus and they are great! Smoother ride than the OEMs, no more Ackerman effect and they feel very stable in the corners too, even though they are all seasons. I will probably need to replace the rears later this year (or early next year) and at that time I will get the same matching tires. I know that it's not ideal to mix tires, especially not all seasons and summers, but I've done it before on my C5 and C6 without any issues. If I was taking corners at the limit of the car I can see it being a big issue, but not with my driving style (I'm gentle on tires, hence the fact that I got 32,000 miles out of the fronts and should get over 40k out of the rears) I also very rarely drive it in the rain, so that is a big factor in my favor too.
FWIW, I'm still running the factory alignment, and the car is lowered on stock bolts, so getting 32k out of the fronts isn't too bad all things considered.
If your car has the Michelin Pilot Super Sport factory tires-
Keep in mind that Michelin came out with a different tire design (different sizes of course) for the C8 and will some day discontinue the PSS model tires that came on our cars from the factory.
If you replace just the fronts, you might discover that the PSS rears are not available when you go to replace them, you'd have to run mixed versions front vs rear; or buy all four again.
I would consider replacing all 4 PSS now, save the old ones for emergency use if you ruin one of the new PSS and can't buy a replacement.
