I just dropped the hex wrench on my shifter while trying to install a blendmount. Tried rubbing it out to no avail. Can I replace the top piece where it says 8 speed or would I need a whole new shift ****?
Ughh..
I may work on it some more or maybe I should just leave it. Damn that was painful. Everything can be repaired for a price I guess. Lesson learned.. always put a towel down first.
Mine was at the body shop for some paint correction and while there they dinged the shifter ****. No saving it. I just replaced mine. Save yourself the aggravation.
Thanks for the suggestion. I found a nice decal on ebay made especially for the top of the shifter. It has the flags logo on it. I will also use a little touch up paint if the decal doesn't completely cover it.
You can get just the **** /it comes with boot attached though easy to replace.. A8 phenomenal transmissions.. so much faster cars than the manual trans. I have had nothing but great experiences Street & Track.
Yep, as per my post #6 the entire assembly is only $85. Replace it and call it a day.
"Yep, as per my post #6 the entire assembly is only $85. Replace it and call it a day."
Yes, fairly easy to get the console lifted off.. hardest part is applying that super strong pull upward to "pop" shifter **** off... be careful not to pull everything else apart lol
Yep, it’s one of those things you will notice every time you shift from park/reverse to forward. You’ll always see it’s not “perfect).👍
Boy that's for sure ! And I haven't stopped thinking about this train wreck since. Car only hast exactly 1300 miles on the dot. Guess I should have take note of that and not touched anything !
