TCM Update
I’ve had the triple flush done but have never had the TCM software updated.
Is there a TSB for this software update?
Im not sure if the update was a stand alone item or not.
If not then I’d like to look into it if it helps prolong the TCC.
OP , ask the dealer to run the VIN to see if you have the latest update
Dave
The description clearly states that it modifies torque converter lockup . I use 2 day passes otherwise I would log in and post it
Dave
The problem really is not the fluid , it's the programing on how the TCM locks up when in AFM mode . The converter never really locks , it is pulsed by the TCM , this limits the harmonic vibrations that are caused by going into 4 cylinder mode
GM in an attempt to keep AFM changed the fluid to compensate for the shudder that was caused by the pulsing under the guise that the old fluid was hydrosocpic but that is a bandaid and we all know it
After all these years suddenly we have a problem with fluid being hydroscopic really ????? Cut me a break ...
I then tuned out AFM .... now I don't really care how the converter locks up because it will never go into AFM mode
AFM was a failure in the 80's for GM , failed again in the 90's , and once again it was a failure in the early 2000's all for the same reasons, mechanical failure on the parts needed to make it work and vibration when it was working but yet GM keeps trying in the name of the GOV mandated fuel economy standards that are set at stupid levels
Dave
Dave
The question would be is , are u experiencing issues , there are plenty of people like me who have the old fluid and no problems
if so what are the symptom as not all problems are cured with the flush which is what caused so may unhappy A8 owners , dealers were just doing the flush for anybody who complained about anything and then when the flush did not solve the issue everybody started to bash the A8 ....
If it's not broke don't try to fix it ..
Dave
I changed the ATF fluid myself. Believe it or not 4X. 2x with the 'black' label and 2x with the 'blue' label.
Did it in my garage using my QuickJack and a Mytie Vac. Sucked it out and pumped it in. Car had less than 1500 miles at the time. Since I did the exchange myself the software was never 'updated'. The trans runs smooth and shifts great.
Was just wondering if everyone who has the fluid changed at the dealer did their trans get the software update or not and is it really necessary.
BTW I have tuned out the AFM on my car as soon as I got it. No V4 mode.
Dave
