Air conditioning issues
Old May 1, 2021 | 03:18 PM
C78353's Avatar
C78353
Default Air conditioning issues
Recently purchased a 2019 Grand Sport and the air conditioning system intermittently blows warm air instead of cold air. It is more noticeable after having stopped for a few minutes and then taking off from a start. While it is parked, it is blowing cold air but once I take off it blows warm air for 20-30 seconds. Has anybody else experienced this issue?
I have taken it back to the dealership two different times and they keep replacing the expansion valve and that still doesn’t solve the problem.
Old May 1, 2021 | 04:11 PM
laserdude2215's Avatar
laserdude2215
This is generally a symptom of a low refrigerant charge, but you would have a warning message and the dealer undoubtedly checked with gauges.
So, I would suspect one of the temperature sensors is intermittent. There is an evaporator temp sensor and four duct temperature sensors. These can easily be checked with a scan tool that is able to read HVAC Control Module data.
BTW, do the passenger and driver side both lose cooling?
Old May 1, 2021 | 05:13 PM
C78353's Avatar
C78353
Thanks for the info.
amd yessir, both sides lose cooling.
Old May 1, 2021 | 05:57 PM
4thC4at60's Avatar
4thC4at60
HVAC problems are a known factor with the C7 - though dealers and, I assume, GM/Chevy deny it.
Old May 1, 2021 | 09:18 PM
Kvou812's Avatar
Kvou812
I had a different vehicle where the AC blew warm air every time I gave it gas, whether parked or not. When I took my foot off the gas the air turned cold. Turned out to be vacuum leak from a vacuum hose.
To Air conditioning issues
