Had her up on the QuickJack today for an oil change and brake pads...
After I was done with about everything, I Put the wheels on. Torqued the rears. Then lowered the jack to the point where the tires just start carrying some weight. Then torqued the front.
I got distracted with a phone call...then began cleaning **** up, gathering tools, organizing the mess and throwing out oily towels n such. Disconnected all connectors for the QuickJack...
Then.......
Dammit. "face...palm". The car is still ON the lift. I couldn't get ANY of the connectors to reengage. So annoyed with myself.
Suggestions? Right now, I brought the two longer hoses inside along with the power unit. The garage became very warm. I'm thinking maybe having the hoses, fluid and connectors "cool" will help eliminate any heat expansion issues that may be causing the problem.
I remember this issue with my old quick jacks. If memory serves me right, you loosen the pressure valve below the hose connections on the control unit, then tighten. This will release enough pressure to connect your hoses again.
Did you try to press the down button while pushing the fitting together? That always works when mine doesn’t want to lock in
That should do it! Don't try my approach, of using brute force to attach a connector. I did, however, start a thread last year on how to clean hydraulic oil off of shoes, clothes, skin, concrete, car paint, walls, etc. Let me know if you want a link.
I'll try that. But it seems like it's the hoses themselves that have the pressure issue. ...based on how the quick disconnect fittings work, it appears that the hose fittings (female end) aren't retracting enough.
HA! Jon, I've been visualizing that very threat! Literally as I'm sitting here waiting for my coffee to do it's daily magic...lmao...wondering and considering worse case scenarios of that exact mess.
My problem is ALL hose connections are disconnected. If I can manage to get them to connect to the unit, then I'm certain this will work.
Worse case I guess is I'll take the hoses outside, put a bunch of spill mats down and loosen the threads until fluid oozes out a little. Re-tighten, clean and try to reconnect.
Hold the down button on the remote while you try to connect the fittings. I have to do this to mine every time I hook it up.
Finally got the hoses hooked up to the power unit...pressing the down button did the trick.
But I can't get the hoses to connect to the actuators. Doesn't budge at all. Held down the "DOWN" button for a few Mississippis before trying AND held it down while trying to connect.
I could try the relief valve on the unit....or, open the threads a little on each leader line till is seeps a little, let it run a for a few seconds then tighten back up and try again.
I'll call Bendpak if I can't get this squared away.
Can't you just jack up the car with a regular jack and put it on jack stands on the other support locations to relieve pressure from the hydraulic system?
That's a good point. I read too fast and missed where he mentioned that he's still got weight on the lifting cylinders.
I'd definitely go with your suggestion to take the weight off. Trying to bleed the cylinders while they're loaded could get dangerous.
just wipe the mating surface of the hose coming from the stands... then take a blunt object and press in the center "plug".... should be able to bleed off some pressure....
Oooooo...didn't think of that threat...and probably wouldn't help as I really think of it since the lift IS weighted right now.
I'll put her on jack stands to relieve the load. Then maybe that will allow me to reconnect to the actuators. If that doesn't work, I'll just slide the units out from the car and deal with it later.
Yes, I can lift with a regular jack and install jack stands. I'm gonna try that...been on hold with BendPak waiting on tech support...for an obscene amount of time. Haven't spoken to a human yet at all.
It's ridiculously obvious that I WON'T do this again. LOL.
interesting idea. I'll try a lesser evasive and violent avenue first. LOL. Then perhaps resort to something like that.
As a former QJ owner, I agree. If I'm understanding correctly, the car is elevated with pressure on the hydraulic cylinders versus down on the locks and pressure removed. Permitting it was on the locks, by design, you are able to remove the hoses.
I jacked the rear of the car and put in two jack stands. Went to the front and....could NOT jack. The car dipped nose low on the QJ and the QJ units were also lifting since the weight of the car was now forward somewhat. With the car nosing down some, the jack couldn't fit under...and I have a long reach low profile jack.
Lowered the rear back on the QJ. THEN I was able to slide my jack under the front. Put Jack stands there. Then jacked up the rear just enough to separate from the QJ. And voila! Hoses connect like buttah. I raised the QJ with the car to the first detent. Removed all the stands and jack. Then PROPERLY lowered the car and.....all was well.
Gentlemen, thank you for you help and input. Man what a pain in the *** I created for myself. BUT, learned a few things and hopefully a few others did too on here.
