Hard tires
Old May 6, 2021 | 10:00 AM
Rabbi's Avatar
Rabbi
Banned Scam/Spammer
Default Hard tires
I recently put these on
PILOT SPORT 4S
but they ride very hard. It's a DD and I'm too old to enjoy a rough ride. Any suggestions???
Non run flats I'm sure will be softer. Ran non RF Michelins on C5 for over 80k with no issues.
There was a post about Continental riding nice
Old May 6, 2021 | 10:02 AM
Elk's Avatar
Elk
What tires were on your car before the replacement? Did you like the ride those tires provided?
Old May 6, 2021 | 10:07 AM
Rabbi's Avatar
Rabbi
Banned Scam/Spammer
Car had 32k on it so tires weren't that good. Non run flats are probably better.
Old May 6, 2021 | 10:15 AM
Jeremie Fischer's Avatar
Jeremie Fischer
I've got Continental Extreme Contacts on my Z06 and they ride much nicer than the Cup2s that came on it. Don't perform near as well, but the car is my daily and if I ever track it I'll swap out the wheels and tires for a track setup.
Old May 6, 2021 | 10:49 AM
seniorstorekeeper's Avatar
seniorstorekeeper
I agree with the Continental Extreme Contacts, my car rides much smoother and quieter than it did with the Michelin run flats. Just made up a little emergency road kit in case it was needed, hopefully won't need it.
Old May 6, 2021 | 10:56 AM
Patfitz9's Avatar
Patfitz9
For a smoother ride, go for non-runflat, all season, and the tallest sidewall that you're willing to accept.
Old May 6, 2021 | 11:28 AM
orca1946's Avatar
orca1946
Andput the car in touring or eco mode. Did you think a Vette would ride like a lexus?
Old May 6, 2021 | 11:38 AM
John Harry's Avatar
John Harry
St. Jude Donor '10-'11-'12-'13-'14
OP: what tire pressure are you running?
Old May 6, 2021 | 12:14 PM
Yes, non-runflats generally give a much better ride than runflats due to the very stiff sidewall on the runflats.
Old May 6, 2021 | 12:28 PM
Bird67's Avatar
Bird67
My 2016 Z51 came with summer-only Michelins. Even though they only had 1000 miles on them when I bought it I swapped them off for Michelin A/S 3+, an all-season run flat tire. The difference in ride quality is night and day. The Contis were about $150 cheaper but I opted for the run flats for the peace of mind. I'm sure I would have been equally happy with either as compared with summer only Michelins.
Old May 6, 2021 | 12:53 PM
JMII's Avatar
JMII
the OEM setup with low profile run flats isn't ideal when it comes to ride quality. So different wheels and tires, plus putting the mag-ride into Touring mode smooths things out nicely.
Old May 6, 2021 | 12:59 PM
Ron_Attleboro_MA's Avatar
Ron_Attleboro_MA
I agree with Bird67.
I have a 2017 Grand Sport. Last year I put the Michelin AS3+. The ride is better but still hard. The steering is wonderful, one-hand relaxed driving.
Continental ExtremeContact DWS-06 Plus Non-Run-Flat tires will rides even better. I would love to ride in a C7 with the Conti's to compare.
Old May 6, 2021 | 01:03 PM
duckvett's Avatar
duckvett
2023 C7 of the Year Winner - Unmodified
2018 C6 of Year Winner
Waiting for the op to answer about tire pressure. I have seen so-called "experts" at tire shops put 40-45 psi in new tires.
Old May 6, 2021 | 01:28 PM
Ultimate ride's Avatar
Ultimate ride
I checked the tire pressure when I got my car used and found the dealer had put 45 psi in all four tires. What a difference in ride increasing the pressure 10-15 psi can make!
Old May 6, 2021 | 02:14 PM
Vette Jockey's Avatar
Vette Jockey
Roadster Madness. 😠
St. Jude Donor '13, '20-'21
Good thing you checked!
Old May 6, 2021 | 06:17 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Lots of people claim that the Michelin AS3+ runflats have a softer ride than the factory PSS runflats. I haven't experienced that.
The first thing we did after buying our 2017 was to get a spare set of factory wheels/sensors, and install new AS3+ runflats for winter use. We swap between the two sets of tires every Spring/Fall, and keep the pressures at 30 psi cold. After doing the swap eight times now, I can't detect any improvement in ride when using the AS3+. Our car is a 2017 Z51 with Mag Ride and the computer upgrade from several years ago. Both sets of tires have about the same miles (15k-20k each).
Old May 6, 2021 | 07:28 PM
Kaya1905's Avatar
Kaya1905
What is tire pressure
To Hard tires
Old May 6, 2021 | 09:45 PM
DALE#3's Avatar
DALE#3
Non run flats and Triple A go together like Pea's and Carrots.Is it worth a chance of a flat?Or possible rim damage.Your misery,your choice
Old May 6, 2021 | 10:20 PM
Cbr600F3!'s Avatar
Cbr600F3!
What is the best TRACTION tires for 2019 C7 Z51 above factory run flats..........so far I love the traction on my factory original tires.
With traction control off with stability off as well, these tires perform well. Like to know if there are any tires fitting factory rims that give better traction than original.
Old May 7, 2021 | 05:35 AM
Bird67's Avatar
Bird67
OP, I think you're going to have to do what I and many others had to do. With so many varying opinions you just have to toss a dart and choose among the obvious contenders. In theory NRF, with softer sidewalls, should give the best ride. Certainly that was true when RF tires first hit the market. Technology has improved and the ride difference today is for many imperceptible. What made the choice for me was (a) the number of people who went with the RF 4S Michelins and loved them, and (b) the terrifying image of a driver for AAA hooking up my C7 and dragging it onto a flatbed. The odds that the tow would damage the C7 seemed unacceptably high for me...I'd rather have the ability to drive it to my Indy for tire replacement than have to have it towed or flatbedded there...my $0.02.
