Bad Gas
Old May 12, 2021 | 12:54 PM
Droop's Avatar
Droop
Vette Jockey, I agree it could turn out to be a real problem, but I have faith in this forum someone will have an answer. I’m am finding that the old days with Corvette have left the building....... Droop
Old May 12, 2021 | 01:02 PM
Droop's Avatar
Droop
Laserdude2215, I didn’t think this was going to be an easy problem... I believe in the KISS principal “Keep It Simple Stupid”. This is not happening on these newer Corvettes... Droop
Old May 13, 2021 | 09:17 AM
Larry/car's Avatar
Larry/car
The gasoline probably will still work (don’t go by the smell). I have an old car that sat for over three years and the engine fired right up with the old gas. Now I didn’t high power the engine and fuel mileage sucked but it did run. Before I would slop gasoline; see if it will run!
Old May 13, 2021 | 11:48 AM
Droop's Avatar
Droop
Larry, I am going to try and start the vehicle just to see if it starts. Put Sea Foam in the fuel last night. Today I’m going to disconnect the fuel line from the fuel rail and bump the starter to clean the fuel out of the lines and get some of the Sea Foam into the fuel system. Let it sit for a day. Check the fuel that came out of the lines, order a new fuel filter to be put in after I get the old fuel out won way or another... My 2014 is a different animal than my 1970 I’m finding out. I’m goin to try and start the vehicle if it shows no water or thickness in the fuel “varnish”. If that is OK we will fire her up tomorrow. Sorry used the wrong word “fire”. Should of used “start”. What do you think?????Droop
Old May 13, 2021 | 12:24 PM
1998prince's Avatar
1998prince
Also, how was the car stored during this time? Inside a normal garage, you might be ok. I ran across an old gas can in my garage and put the gas in my lawnmower and it was fine.
Now if the car was outside and experienced the climate changes, you do have an issue with the fuel.
Old May 13, 2021 | 05:31 PM
John Harry's Avatar
John Harry
St. Jude Donor '10-'11-'12-'13-'14
Originally Posted by Droop
- - - order a new fuel filter to be put in after I get the old fuel out - - -
Note that the fuel filter is in the tank and is a major job to replace.
Old May 13, 2021 | 06:57 PM
RonC7's Avatar
RonC7
Fuel filter is part of the left tank pump / level sensor assembly. You need access to the top of the tank to remove - that is the tank needs to be dropped!
Pouring anything into the fuel filler now will overflow into the right tank and won't help you for a while until the tanks circulate a bit.
Just thinking - follow the procedure linked in post #9 to empty the left tank, refill with at least 8 gal of gas to dilute. The fresh gas in the left tank will dilute the old gas...
Ron
Old May 14, 2021 | 08:06 AM
jimmie jam's Avatar
jimmie jam
Droop, you could be over thinking this fuel thing. My 2016, 1,055 mile vert had been sitting on the lift due to my battle with cancer. Two weeks ago the lift was lowered and I started it for the first time in 37 months without issue. I let the car idle for about 45 min. before driving it, then just taking it easy. I also cycled the A/C and heat to circulate the coolant everywhere while idleing. I have had no issues and have driven it 3-4 times now. Top tier 93 fuel should last about a year without help. Sta-bil will keep the fuel for about two years if fresh and added to a full tank which I did. Tires set @ 40 PSI and tender plugged in. My garage is climate controlled which helps. You could be opening a larger can of worms by unnecessarily tampering with the fuel system. IF you are asking my advise, I would use some treatment designed to absorb moisture from fuel and a injector cleaner, start the car (yes, it will run) and slowly get it moving on the street. Burn as much of the fuel to about 1/2 tank before adding fresh fuel. Then, IF you have issues, mess with the fuel system. I don't think that you will...
Old May 14, 2021 | 10:37 AM
Droop's Avatar
Droop
1998prince, The car was stored in a great garage, Raised up on jack stands so the tires were just touching the floor. Totally covered..It was their Pride and Joy...Droop
Old May 14, 2021 | 10:41 AM
Droop's Avatar
Droop
John, I’m ordering a shop and parts manual in the next couple of days....It figures the fuel filter would be in the fuel tank.. Droop PS they don’t make it easy anymore.
Old May 14, 2021 | 10:46 AM
Droop's Avatar
Droop
RonC7, It looks like we I have to do a multitude of items to get this right.
Old May 14, 2021 | 11:03 AM
Droop's Avatar
Droop
Jimmie Jam, The C7 as you can see is new to me. I know the owner alway did the best for this automobile. My bother who is a Mopar Head basically said the same thing. Keep it Simple Stupid...You can always do the other items if this doesn’t work. I am going to take your advice. This afternoon after I put things back together. I will let you know tomorrow have it turned out. Jimmie hope all is well with you....Thanks Steve
Old May 16, 2021 | 11:13 AM
  #33
Droop's Avatar
Droop
Larry, You are right about the smell...I went with Jimmie Jams Theory first, it worked . We did have to put some fuel components back together before we started the 2014. The fuel we tested turned out to be ok. No moisture and or odor, just ok. Fuel you could run in your lawn mower. We did learn form the guys on the C7 Forum that if you think you have some “Bad Fuel" this is the place to come. All the ideas we received were helpful and we would of tried them in some sort of order. Again thank you for everybody’s help...... Steve
Old May 16, 2021 | 11:21 AM
  #34
Droop's Avatar
Droop
Jimmie Jam, Thank you again...It worked..Another Happy New C7 Owner. Again I would like to thank everyone who Helped With the “Bad Fuel” problem...Droop
Old May 16, 2021 | 11:29 AM
  #35
Pb82 Ronin's Avatar
Pb82 Ronin
Disconnecting the fuel line at the rail and draining it into a bucket or fuel can is your best bet. For a cleaner event, just run an AN fitting with a length of fuel line over the fender an out of the car. Turn the car to "ON" and get it all out of there.
