I just randomly looked at an Owner's Manual (2016 in this case) for the reindexing procedure and here is what it states:
Window Indexing and Express-Up Reset Window indexing may be required if the vehicle battery has been
recharged or disconnected, or is not working. Express-up and the convertible top will not function until the windows are reset.
After battery power is restored, a message displays in the Driver Information Center. See Driver Information Center (DIC) 0 114.
Once power is restored:
1. Close the doors.
2. Start the vehicle.
3. Hold the window switch up to the fully closed position.
Hope this helps.
I'm due a new battery, Jack.......soon I suspect. Thank you for doing the legwork on this. I hope my 2017, built in 2016, indexes properly. I hope, anyways........😔
When I changed the battery a message to index the windows came up in the speedometer area. I did it, as was mentioned, and everything worked fine after that.
Maybe, disconnect the battery for 10 minutes, again, and see what happens.
