I changed the diff fluid on my 2014 C7 Z51. I measured the drained fluid, and it was about 92 ounces, about 4oz less than 3 quarts. It didn't look as bad or smell as some photos I have seen. There was a little build up on the drain plug magnet, but not too bad. I filled with the same volume that I drained, and it was just starting to come out the fill hole. I used the 75W-90 Delco fluid that is recommended.
Accessing either the drain or fill holes was easy. It was a pretty easy job. Also, I used a narrow funnel placed beneath the drain plug and there were no messes.
How did you get the new fluid up to the fill hole?
I had to use a simple drill-attached pump on my GS. It's just too crowded up around the fill hole to allow a normal gravity-fed fill, or if there is a way I couldn't figure it out. As for pulling the plug, a universal joint attached to the ratchet is a must.
did u change it fully cold or after a drive and cool down? i was going to drive about 5 to 10 miles and let cool down about 40 mins or so, enough to get it lifted and things gathered up to get it rocking.
I plan to try to tackle an oil change, transmission, and rear end all at the same time but probably asking for problems trying to do so much.
I took my 17 GS in for tranny triple flush and asked to check the diff, they didn't tighten the fill plug!!! We went on a road trip and saw fluid leaking. Had a local tire shop tighten it for me.
