Negative battery terminal stud
Old May 28, 2021 | 06:12 PM
baxsom's Avatar
baxsom
Default Negative battery terminal stud
Boneheaded move on my part. I was taking the neg battery terminal Off and loosened the nut too much. Found the. Nut and washer but the actual square headed stud seems like it vanished into a black hole. Any suggestions on a suitable replacement?
Old May 28, 2021 | 10:23 PM
Have you tried the parts department at your local dealer? How about checking with the forum's used parts vendors - someone like aescorvetteparts that seems to part out C7s every now and then.
Old May 28, 2021 | 10:27 PM
baxsom's Avatar
baxsom
Dealer told me I’d have to replace the entire cable. Ended up finding the stud on amazon for just a few bucks
Old May 29, 2021 | 01:27 AM
Vette Jockey's Avatar
Vette Jockey
Roadster Madness. 😠
St. Jude Donor '13, '20-'21
I have a telescoping magnet I always use if something metal disappears down a space. Maybe, that will help. If it is not metal, l I have a long cable with grasping fingers.
To Negative battery terminal stud
