Cooling fan control module
Old Jun 5, 2021 | 12:10 AM
psxer989's Avatar
psxer989
Default Cooling fan control module
I have a 2014 with intermittent fan issue. Sometimes it just doesn't turn on and when I turn off the engine and immediately restart, the fan comes on. I've seen posts that it might be the fan control module but I can find a part number for it. Does anyone know it? I tried replacing the coolant tank cap but that didn't fix the issue.
Old Jun 5, 2021 | 12:14 AM
Bill Dearborn's Avatar
Bill Dearborn
A common issue with the 2014 cars. Purchase the 600-watt fan used on the 2015+ C7Z and the problem will be resolved.
https://www.cultragfactoryparts.com/...bC12OC1nYXM%3D
Bill
Old Jun 5, 2021 | 12:21 AM
psxer989's Avatar
psxer989
Thanks! I'll source one.
Old Jun 5, 2021 | 02:27 AM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
The fan controller is part of the fan unit. There is no separate fan controller available to r/r. When you get the new fan mentioned in post #2, the controller comes along for the ride.
Here is how to replace the fan: https://www.corvetteforum.com/forums...-to-260-a.html
Elmer
To Cooling fan control module
