Crazy gas cap
Old Jun 9, 2021 | 04:53 PM
C7nut's Avatar
C7nut
Default Crazy gas cap
I've read about the gas cap issues for years with the C7 but not this.
It seems like sometimes but not every time when I unlock the doors with the key fob, the gas door pops open with the unlocked door. I cannot figure out how to address this crazy problem. Any ideas? Thanks
Old Jun 9, 2021 | 05:14 PM
Vette Jockey's Avatar
Vette Jockey
Roadster Madness. 😠
St. Jude Donor '13, '20-'21
This is the first time I have read about something like this. Hopefully, someone will have the answer.
Old Jun 9, 2021 | 05:46 PM
Maxpowers's Avatar
Maxpowers
Never heard of this one before. Keep us posted.
Old Jun 9, 2021 | 05:50 PM
wayback's Avatar
wayback
Mine has unlocked when I open the drivers door a few times. Usually when I exit the car. Weird. Does not happen very often.
Old Jun 9, 2021 | 05:54 PM
KLG's Avatar
KLG
I am guessing when you say the fuel door pops open when you unlock the doors, it opens maybe 1/4" or so?
If so, what may be happening is that the fuel door is not latched although it is locked and when you press the FOB unlock button, the fuel door lock releases and the fuel door opens about 1/4".
Try this...With the doors closed and the fuel door fully closed, lock the doors. Next, press on the fuel door as if you want to open it. This releases the latch but not the lock. When you do so, you should notice the door pops out ever so slightly, barely even noticeable, but, it will not open because it is still locked. Now, press the FOB door unlock button. The doors will unlock and the fuel door will pop open about 1/4" or so.
Hopefully this addresses your concern.
Old Jun 9, 2021 | 06:53 PM
C7nut's Avatar
C7nut
Thanks for the tip. Today as I walked up to the locked car in a restaurant parking lot I pressed the FOB, when got the car the gas door was open a crack. This has happened infrequently but it concerns me.
I have tried to duplicate the problem but it stays locked every time I try, frustrating
BTW, as I was typing this while listing to the news, they were promoting new stingray decorated corvettes at the upcoming Detroit grand prix this weekend, the reporter said GM will unveil a new car tomorrow at the Ren Cen.
Old Jun 9, 2021 | 08:12 PM
Gixxerman's Avatar
Gixxerman
Moderator
St. Jude Donor '18 thru '25
Yeah, interesting.. no gas cap on the C7 and the door is pretty much only locked or unlocked.. even unlocked you have to manually open it, would not think that is possible for it to "pop" open. Keep us posted,
Old Jun 9, 2021 | 08:40 PM
C7nut's Avatar
C7nut
My thoughts as well but I should not have said poped open as I found it open just slightly, enough to. know it was open.
Makes no sense as opening the gas door is a manual operation.
Old Jun 9, 2021 | 09:33 PM
mickeyone's Avatar
mickeyone
When I have tried to open the gas cap without my FOB nearby, it will pop open when I do go to open the car.
Maybe someone is bumping in to the gas cap without realizing it or they are just fooling around with your car.
Old Jun 9, 2021 | 10:24 PM
I have not noticed anything like this happening to my C7, but hope you can find out a definitive reason for it happening to your car.
Old Jun 10, 2021 | 01:43 AM
Avanti's Avatar
Avanti
I blocked off the "locking-pin" hole right after I got my '18 so I wouldn't be blocked if it glitched, as some have been over the years. Hence, I'm always sure if I push the door completely latched and it catches correctly.
Old Jun 10, 2021 | 06:07 AM
KLG's Avatar
KLG
I suppose the issue could be that the fuel door latch is not working consistently. When the latch isn't working, I am guessing that it is the fuel door locking mechanism that is holding the fuel door closed until you press the FOB unlock button.
--KLG--
Old Jun 10, 2021 | 07:20 AM
eseibel67's Avatar
eseibel67
--KLG--
^This answer is correct and is the only physical way the problem that the OP is having could possibly occur.
Old Jun 10, 2021 | 09:13 AM
C7nut's Avatar
C7nut
--KLG--
Makes complete sense. I wish I would have thought of that before posting. Thanks
Old Jun 11, 2021 | 12:58 PM
Tally Ho's Avatar
Tally Ho
From: Out Where the Buses Don't Run, Eglin AFB/ Niceville FL
2022 Corvette of the Year Finalist -- Modified
2021 C6 of the Year Winner - Modified
2020 C6 of the Year Finalist - Modified
I did a little experiment with my Z06 today concerning your issue. While locked i tried to open the fuel door and of course it stayed locked. As soon as I hit unlock on the fob the fuel door popped open. I tried this a couple of times and the result was the same. I suspect in your situation someone may have pushed on the fuel door while locked and then it popped open when you unlocked the car. If it is a continuous issue then someone is messing with your car or your release mechanism is at fault.
Old Jun 11, 2021 | 01:11 PM
mickeyone's Avatar
mickeyone
Exactly right
To Crazy gas cap
