Hello - I'm curious - if there is an accessport available where you can keep it plugged and change tunes on the fly? I think I saw something like that but it didn't really explain much about being able to hotswap tunes. I only ask because I'm thinking of doing the E85 flexfuel thing and would like to be able to flip and flip back and forth depending on what's available. Thoughts?
Oops... and here I thought at first you wanted to change your music as you drove. That aside, mucking with the engine computer on-the-fly sounds very risky to me.
There is no such device for the GM ECU's. IT is more the ECU itself rather than the technology to do so. The Cobb AP's can do on the fly tunes with Subaru's and a few others because the factory ECU's allow this sort of communication. The GM ECU's do not, or at least it has not been figured out yet.
If you're going to do E85 Flex fuel, why do you want to swap tunes? Flex fuel means the ECU automatically adjusts to the Ethanol content and adjusts the tune on the fly. I really don't see any reason on a non turbo car to have adjustable tunes on the fly. The only reason to adjust on the fly in a turbo car is because its easy to turn down the wastegate and drop timing so that you can vary power levels at WOT. That is not the case with the LT1 or LT4.
The only reason I could see anyone wanting to be able change tunes on the fly is for race fuel.
OP, what he means by "turning down the wastegate" is the ECU can control boost by opening the wastegate sooner to limit PSI, it can also keep the wastegate closed longer to run a higher PSI.
Oh ok - I was more thinking if E85 is available I can have it and then be on a tune that uses it but if its not available can be on a normal 93 tune. Obviously I come from turbo cars so Im' a bit...new to the corvette platform limits. Thanks for explaining!
You can do that, a flex tune will allow you to run straight 93 by itself and E-85 up to whatever percent ethanol your fuel system will allow. Without fueling upgrades you will have to mix 93 with E-85 to get a lower percentage of ethanol such as E-40.
The important part here is the Flex Fuel sensor.
Who does this magical tune? I haven't been able to find it anywhere's (probably because my search parameters are crap hahaha
I am one of many remote tuners that use HPTuners to tune cars for flex fuel and other mods. It requires the owner to have their own HPTuners software and cable and to license their ECU. You can find a few tuners on here and a few more on HPTuners forum.
You can either go with a remote tuner or take it to a reputable shop to have it dyno tuned. Either way, do your research on the tuner before letting them tune the car.
You will need a flex sensor installed to run E-85.
Where are you located? People might be able to chime in and tell you where to take it that's reputable.
