Flutter at variable speeds
Old Jul 9, 2021 | 11:01 AM
ILOW93's Avatar
ILOW93
6th Gear
Default Flutter at variable speeds
2017 Stingray I have a flutter while driving. The dealership states they can not duplicate the problem , I have only had the car for two weeks and have not enjoyed the experience any ideas on what could be costing this problem because it seems as if i will be fixing this out of pocket
Old Jul 9, 2021 | 12:21 PM
Flame Red's Avatar
Flame Red
You have a manual or an auto? If auto - Flutter, maybe you mean shutter? If so, welcome to the GM A8. Literally hundreds of threads about it here. Best one is: https://www.corvetteforum.com/forums...-tracking.html which is a sticky at the top of this forum. The common fix is to have the Stealer do a A8 triple flush procedure. It works for many. For others, the converters are too far gone.
Old Jul 9, 2021 | 03:25 PM
SmittyC7's Avatar
SmittyC7
More info. M7 or A8, what rpm etc.
Old Jul 9, 2021 | 06:22 PM
ILOW93's Avatar
ILOW93
6th Gear
I drive on a flat surface to work each day when i get to where the road inclines i feel not sure about the RPM , but the deanship got back with me and they will be dong the flush and I have ordered the edge.
Old Jul 10, 2021 | 07:58 AM
jabolletta's Avatar
jabolletta
4th Gear
Our ‘14 did something similar when the engine was going in and out of v8 w/afm. The belt tensioner was the problem, replaced it and the flutter went away. Then we installed a range device to prevent it from going in and out of v8 mode.
Old Jul 10, 2021 | 04:16 PM
DTOM's Avatar
DTOM
C7 of Year Finalist (performance mods) 2019
If auto, try putting it in manual mode and see if the issue persists.
If its a major repair, consider finding a local reputable speed shop that specializes in our cars rather than paying dealership costs.
To Flutter at variable speeds
