Battery tender Jr
Old Jul 12, 2021 | 09:39 AM
Vette Ski's Avatar
Vette Ski
Default Battery tender Jr
Hello all,
My sister has a 2017 Z 51 and purchased a Battery tender junior 750 mA while ago. I see an adaptor to plug into the rear port of her Vette. Is this tender OK to use on the Vette, I thought the Jr. was for motorcycles and small batteries
Thanks, Rich
Old Jul 12, 2021 | 09:47 AM
AZRenegade's Avatar
AZRenegade
That's what I use on my motorcycle. I use an Optimate 6 on my Stingray. To date, no problems with either.
Old Jul 12, 2021 | 10:48 AM
Maxpowers's Avatar
Maxpowers
I also use that for my bike. It will work on the vette but the amps are pretty low. It will maintain but I wouldnt use it to charge.
Old Jul 12, 2021 | 10:49 AM
Buddhaman's Avatar
Buddhaman
I use a Battery Tender JR for all my vehicles when needed. It’ll still maintain your battery but it would take slightly longer to reach full charge first. I’ve never had any issues between 3 motorcycles and 4 cars.
Old Jul 12, 2021 | 11:30 AM
Vette Ski's Avatar
Vette Ski
Thank you, will she will need the adaptor to plug into her hatch port ? I did not see the unit. This is my unit, It is a US 3300 Corvette ( model 1051)
Thanks again for your input,
Rich
Old Jul 12, 2021 | 12:27 PM
John Harry's Avatar
John Harry
St. Jude Donor '10-'11-'12-'13-'14
BT Jr. is fine. Nothing wrong with a slow charging rate, as it's supposed to be a maintainer, not a charger.
Old Jul 12, 2021 | 04:32 PM
Globeman's Avatar
Globeman
I've been using BT Jr.s on several vehicles, including Corvettes for years. Never had a problem. I like that the transformer (wall wart) mounts on the elect. outlet. I don't think they come with a 12V lighter type plug. You'll need to order one of these. 12 V Plug
Old Jul 12, 2021 | 05:00 PM
Red08's Avatar
Red08
Originally Posted by Vette Ski
Hello all,
Thanks, Rich
It is absolutely ok to use. The Battery Tender Jr. is all I have ever used on my Corvetts, and I have never had any issues.
Old Jul 12, 2021 | 09:22 PM
Vette Jockey's Avatar
Vette Jockey
Roadster Madness. 😠
St. Jude Donor '13, '20-'21
Same here!
Old Jul 13, 2021 | 03:29 AM
Vette Jockey
Roadster Madness. 😠
Roger, that!
Old Jul 13, 2021 | 08:19 AM
Apocolips's Avatar
Apocolips
I've been using a Tender Jr. for years. I bought it back when I owned a 1970 Corvette, and used it on every Vett up to my 2017 GS. Like others have said, it isn't much good to recharge the battery but works great to maintain it.
Old Jul 13, 2021 | 09:54 PM
johnfin's Avatar
johnfin
I have wondered if the tenders are actually good forvthe battery vs regular service. I took mine off the tender for a week and the car was dead. Has there ever been a study to compare types of charging vs battery life?
Old Jul 14, 2021 | 07:30 AM
Tinkertech's Avatar
Tinkertech
Lead acid batteries have the best results when each cell is maintained at ~ 2.2 volts per cell which equals to ~ 13.2 volts. Which just happens to be the 'float' maintenance voltage of a battery maintainer.
To Battery tender Jr
