VIN and RPO code sticker
Old Jul 28, 2021 | 01:32 PM
GMJim's Avatar
GMJim
Default VIN and RPO code sticker
Does anyone know where the VIN and option code sticker is on a C7. They used to be on the inside of the glovebox door on the C6. Trying to get a friend of mine to send his to me and he says he can't find it.
Old Jul 28, 2021 | 01:39 PM
MyDarkAngel's Avatar
MyDarkAngel
In the trunk on the right side by the battery under the carpet, it will be on the left side under the carpet. (RPO).
Old Jul 28, 2021 | 02:08 PM
JMII's Avatar
JMII
In later years they started using a QR code on the door jam:
https://corvettesalvage.com/where-is...label-located/
GMJim's Avatar
GMJim
Thanks!!! I appreciate the help!
Old Jul 28, 2021 | 02:11 PM
MyDarkAngel
No problem.
Old Jul 28, 2021 | 02:12 PM
MyDarkAngel
For the 2018, 2019, 2020, 2021 GM completely revamped the RPO Code sticker. They moved the silver sticker to the driver-side door and added a QR Code. The RPO Codes can only be read using a QR Code scanner.
Old Jul 28, 2021 | 03:18 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
2014, 2015, 2016, 2017 Silver sticker which is located under the rear compartment carpet, near the battery.
2018, 2019, 2020 GM completely revamped the RPO Code sticker. They moved the silver sticker to the driver-side door and added a QR Code. The RPO Codes can only be read using a QR Code scanner.
https://corvettesalvage.com/how-to-s...our-rpo-codes/
Elmer
Old Jul 28, 2021 | 07:17 PM
Vette Jockey's Avatar
Vette Jockey
Roadster Madness. 😠
St. Jude Donor '13, '20-'21
2016 Z51 Convertible
Old Jul 28, 2021 | 08:02 PM
If your friend has a car where the sticker is near the battery, tell him to be careful when lifting the carpet - it is not thick and has been known to tear when bending it back.
Old Jul 29, 2021 | 01:03 AM
Bill Dearborn's Avatar
Bill Dearborn
Yes, it can tear where it is under the interior quarter panel. The way to avoid that is to slide the carpet a little toward the left so it comes out from under the panel and then lift it.
Bill
Old Aug 3, 2021 | 09:21 AM
GMJim's Avatar
GMJim
Thanks for all the feedback. He found it and we're good!
To VIN and RPO code sticker
