Range or Tune
Old Jul 31, 2021 | 01:32 PM
BigVette427's Avatar
BigVette427
I had my favorite tuner tune my otherwise (mostly) stock (AFE Pro Dry Air Filter,) MY16 Z06/Z07 for a variety of reasons. He's one of the top tuners on LS/LT motors out there and been tuning since the beginning. He also tuned my previous MY12 Z06 when I went with a custom mild cam and heads.
Given mine was a MY16 he was able to tune the A8 at the same time (MY17+ HPTuners started charging more to unlock/tune the TCM I believe because GM started making it more difficult to decrpyt,) and immediately after driving it home, the improvements were noticeable. Reminded me of my previous hi-performance vehicle, an F10 BMW M5 with a DCT.
From the factory, these vehicles are tuned really rich, which is part of the reason why a good tune can also net you an extra MPG or two if you can keep your foot out of the gas. All safe AFR's, etc. A good tuner doesn't put you on the edge of the envelope for a few meaningless peak numbers. Also, if you've never heard of torque management, you'll only get rid of that with a tune. +41rwhp/+40 rwtq on the same dyno, same day, tune alone.
And when I brought my car into the dealer four months later for the A8 triple flush under warranty, they didn't bat an eye and GM picked up the tab. The A8 triple flush is a great time to get the MRC update, as well.
Why take a stock Corvette to a dyno for tuning? The factory chooses settings for air/fuel ratio (AFR), timing and other parameters so that the car’s performance is “good” in a wide range of circumstances: altitudes from sea level to 10,00 feet, temperatures from 40 to 130 F, gas from 85 to 103 octane and engines in various stages of wear and maintenance. Plus, every car is a little different; injectors and other parts are never exactly identical.
A properly executed tune on a dyno will tailor the settings to the actual condition of your car. Then it will run better than just “good,” it will run at its optimum. And the benefit is not only peak horsepower. Power and torque throughout the range can increase to make the car feel better in everyday driving. How long does it take to get these results? Bob Morreale, president of The Tuning School, says that its dyno tuning of a stock late-model vehicle takes about an hour.
https://www.motortrend.com/how-to/16...your-corvette/
Old Jul 31, 2021 | 05:41 PM
spoolin03's Avatar
spoolin03
do yourself a favor and chuck that range device out the window. problem solved.
Old Jul 31, 2021 | 10:14 PM
jdaniels138's Avatar
jdaniels138
Veteran: Marine Corps
As far as AFM, GM should have allowed this to be toggled off even if it defaults back to on when the engine is started. I've driven cars with the stop/start feature that allows this but defaults back to on when the engine is started.
JD
Old Aug 1, 2021 | 08:26 AM
Tinkertech's Avatar
Tinkertech
Originally Posted by jdaniels138
As far as AFM, GM should have allowed this to be toggled off even if it defaults back to own when the engine is started. I've driven cars with the stop/start feature that allows this but defaults back to on when the engine is started.
JD
European A8 Corvettes only go into AFM mode when in Eco mode.
Kinda like our M7 models do.
Old Aug 1, 2021 | 10:51 AM
Elk's Avatar
Elk
Agreed. My BMW allows one to toggle whether the stop/start is activated and remembers this setting even if the engine is turned off. AFM should be treated the same.
Old Aug 1, 2021 | 11:01 AM
AZRenegade's Avatar
AZRenegade
If you do a little research on this subject, you will find that GM's use of AFM on the Corvette was more about politics and meeting EPA standards than common sense. No surprise there.
Old Aug 1, 2021 | 11:25 AM
dan1495's Avatar
dan1495
2016 C3 of Year Finalist
I guess we’re lucky the C7 doesn’t have start/stop. To your point, my 2015 X5 worked as you describe, but my 2019 has to be reset every time you start it. I understand the new ones don’t don’t even give you the option to turn it off any longer.
Old Aug 1, 2021 | 12:06 PM
Elk's Avatar
Elk
I was unaware the newest BMW's no longer act as my car.
I admit the stop/start works perfectly fine. It just annoys me.
Old Aug 2, 2021 | 01:31 PM
TxLefty's Avatar
TxLefty
Makes me wonder how long the starter is going to last. Can turn it off on the Palisade. Resets though.
Old Aug 2, 2021 | 02:06 PM
Elk's Avatar
Elk
A concern, certainly. BMW, at least, installs a much beefier starter good for 8x as many cycles as the previous non-stop/start car's starter.
Old Aug 2, 2021 | 04:00 PM
jaiyenyen's Avatar
jaiyenyen
Originally Posted by jwmgr8
Some good advice in this thread.
I've owned two C7 with A8, a 2016 Z51. It started the shudder at under 1000miles. At that time dealers were told to change the TC. That worked for a while but at about 7k miles shudder started again. Had the triple flush and that seemed to work. The RPM thing I think is caused by AFM system shifting to 4cyl. I had a range device but only used it about a month- it caused a code related to transmission communication so I removed it.
I just got a 2017 GS with A8. I checked with the dealer and the triple flush was performed back in late 2019. I abolutely hate driving a sports car that can not decide to be an 8cyl or a 4cyl? Plus I think the AFM system confuses the transmission and thus we get weird rough shifts at times? So I got a new Range device and its been working fine. No switching back and forth between 8 and 4 Cyl? It seems to run much better.
The Bad Transmission fluid issue has been frustrurating and interesting. A GM tech described it to me as the old fluid absorbed mositure which cause the viscosity to change thus causing the TC to struggle doing its job? It sounds reasonable, but I wonder if the Shudder happens more in high humidity areas vs very dry climates?? The transmission is a sealed system, but even sealed systems can have condensation. Regardless some small group of GM folks know the real truth, and they have figured out that changing to a new transmission fluid fixes the problem. I wish this same group was smart enough to know that 90% of Corvette owners(my guess) hate having a system that goes from 8cyl working to 4cyl kinda working without any owner control. If they just added a on/off switch for the AFM they could call it MFM and there would be so many happy owners and likely lesss complaints about other stuff?
The enviroment ****'s won't accept that.
