Front diffuser installation
Old Aug 28, 2021 | 01:07 PM
1LoveToronto's Avatar
1LoveToronto
Default Front diffuser installation
Question for all those who have installed a front splitter. Due to living in a condo, I don't own a jack.
When installing a front diffuser with the pre-drilled holes into the existing 8-10 bolts under the bumper, how important are the additional rivets/self tapping screws for the edge closer to the front of the bumper? I feel like 8-10 bolts for what is essentially a piece of plastic and a fair amount of double sided tape should be more than enough. Would that suffice?
Old Aug 28, 2021 | 01:55 PM
miami08VETTE's Avatar
miami08VETTE
When I replaced mine I was able to install the rivets and screws without jacking or ramps so with the right rivet gun you may be able to get it done. Not fun but doable. Tape may work but for how long? YMMV. Good luck...
Old Aug 28, 2021 | 02:03 PM
DrivesWithTwoFeet's Avatar
DrivesWithTwoFeet
I just used the existing bolts for installation. This can easily be done without lifting the car. However it might depend on which splitter you use if rivets are required or not.
Old Aug 28, 2021 | 05:12 PM
I8URRICE's Avatar
I8URRICE
I got my Diffuser from ACS and only used the existing Bolts, no Rivets. No issue, three Summer so far.
Old Aug 28, 2021 | 07:04 PM
My preference is to use the existing bolts plus the rivets, but you may be OK with just the bolts.
Old Aug 31, 2021 | 08:06 AM
miami08VETTE
I like or at least always try to use all the parts for given job/install. That's just me...
Old Aug 31, 2021 | 09:12 AM
jaki30's Avatar
jaki30
I didn’t use the rivets, only the bolts.
20k miles and it is still on the car.
BTW, pick up a couple of 2x12” wood boards to drive up on. May help.
I bought a right angle driver and it is still a pita w/o raising the front a little bit.
sgp99's Avatar
sgp99
Take it to a dealer and have them install the splitter with the rivets. Why take the chance on a $400+ item. The dealer installed mine for $120.
Old Aug 31, 2021 | 12:33 PM
miami08VETTE
Cheaper to buy a rivet gun for less that 30 bucks. Harbor Freight has some cheaper than that. Just me saying...
Old Sep 1, 2021 | 08:16 PM
bbrown450's Avatar
bbrown450
On my 3rd C7…do yourself a favor , lose the rivets unless you track. It will make it easier to change out to the next one when you trash it
To Front diffuser installation
