From: Out Where the Buses Don't Run, Eglin AFB/ Niceville FL
2022 Corvette of the Year Finalist -- Modified
2021 C6 of the Year Winner - Modified
2020 C6 of the Year Finalist - Modified
Build sticker question
I should know this since I'm a C7 Z06 owner but where is the build sticker located? I have build sheet for my car so I never looked. I'm looking at 2015 Stingray and want to confirm the options it was built with. Thanks
Just be careful when pulling back the carpet as it has a tendency to rip easily if you are not careful. Best to gently pull the carpet from under the side trim on the passenger side or remove that side trim to help with moving the carpet.
1984, 1985 White sticker located on the underside of the rear, left storage compartment cover (on the driver side) of the car.
1986, 1987, 1988, 1989, 1990, 1991, 1992, 1993, 1994 White sticker located on the underside of the center console lid.
1995, 1996 White sticker located on the underside of the rear, right storage compartment cover (on the passenger side) of the car.
1997, Early 1998 White sticker located on the underside of the rear, left storage compartment cover (on the driver side) of the car.
Late 1998 - 2013 White or silver sticker which is located inside the glove box compartment on the glove box door.
2014, 2015, 2016, 2017 Silver sticker which is located under the rear compartment carpet, near the battery.
2018, 2019, 2020 GM completely revamped the RPO Code sticker. They moved the silver sticker to the driver-side door and added a QR Code. The RPO Codes can only be read using a QR Code scanner.
