Driveshaft replacement
Old Sep 13, 2021 | 06:48 PM
Patman's Avatar
Patman
Default Driveshaft replacement
After 3 1/2 years and 37,000 trouble free miles I finally needed to get some warranty work done on my C7. And it was a bit of a doozy!
On the plus side, it looks like I might have gotten a free modification! (the LT4 flex plate) and it allows looks like they replaced 9L of transmission fluid so I got a free fluid change too (not that I was having any issues with the transmission's behavior on the original fluid)
Hopefully this is the only major repair this car will ever need!
Old Sep 13, 2021 | 10:41 PM
With that much work required, you've got to be glad you did have a warranty in place. Best of luck with the car and hope you do not have any more problems for a long, long time.
Old Sep 14, 2021 | 07:16 AM
Patman's Avatar
Patman
Thanks Jack! The service advisor told me this would have been a $3000 repair bill if it wasn't covered!
I notice now that the back end seems a little more twitchy though, it kicks sideways a little bit over certain bumps. Could they have done something wrong when reassembling the car that might be responsible for this? I don't believe my base model has a rear sway bar though, so it couldn't be that.
Old Sep 14, 2021 | 11:53 AM
TJay74's Avatar
TJay74
I can tell you on my 19 C7Z this was a little over $6k repair bill. The part alone was $4600 for the new torque tube.
Old Sep 14, 2021 | 11:59 AM
Patman's Avatar
Patman
Mine didn't need a new torque tube, I wonder why not though?
To Driveshaft replacement
