My search tool skills have failed me. So, now I am counting on the wonderfully knowledgeable people at the forum.
Does anyone know the part numbers, or even the correct name, for the 3 rubberish pieces that go along under the chin (front) of the car?
You know, those things I hear slightly scrape as I back slowly out of my driveway no matter what angle I utilize.
I searched for deflector, chin, guard, and other similar terms, but nothing definitive came up.
Intersection close to my parents house had a serious dip and I tore them, by not realizing its size until too late. No other damage, just enough to tear where the attachment bolts are.
Lower Deflector - Passenger Side (RH) - GM (22799211)
Lower Deflector - Driver's Side (LH) - GM (22799210)
Just found the 2 outer ones at Getoemparts.com. I believe these are for stingrays. I would double check for your year and model. I did not see the center one on their site.
So commonly replaced that any major parts vendor should be able to simply send you a set if you tell them what year (series) you need them for. That's how I got the replacements for my C5 from Mid America some time ago. No parts numbers or anything else required.
