recirc air intake location?
Old Sep 30, 2021 | 01:03 PM
jerkyboy's Avatar
jerkyboy
Default recirc air intake location?
Where exactly is the interior intake for the HVAC recirc? Is there an intake under the dash somewhere? I'd like to spray in some freshener.
Old Sep 30, 2021 | 02:10 PM
Ron_Attleboro_MA's Avatar
Ron_Attleboro_MA
You can easily lift the hood and spray into the air-intake near wiper blades.
First, open windows, put fan on High, AC and Heat Off. I would put a towel over the interior air ducts.
Are you going to use Fabreze, Lysol, Clorox, or ???
Old Sep 30, 2021 | 04:40 PM
duckvett's Avatar
duckvett
2023 C7 of the Year Winner - Unmodified
2018 C6 of Year Winner
I suggest you change the interior air filter.
Old Sep 30, 2021 | 04:43 PM
Ron_Attleboro_MA
Good point Duckvett. It should be removed before spraying chemicals in near the wiper air-intake.
Old Oct 1, 2021 | 11:40 AM
jerkyboy's Avatar
jerkyboy
Thanks all. Yes I know about the under hood intake with the filter I had a mouse die in the HVAC lines and I was hoping that I could just keep recirc'ing some lysol just within the car. If you put the system on recirc, doesn't that mean it's not pulling outside air (through the filter)? If so, there must be an intake under the dash right?
Old Oct 1, 2021 | 12:41 PM
Ron_Attleboro_MA
Then use a paper to find which vent under the dash is sucking in air while in recycle mode.
To recirc air intake location?
