Gas door question
Old Oct 3, 2021 | 12:28 PM
Raidercop's Avatar
Raidercop
Default Gas door question
Does anyone else's c7 gas door not pop open even tho it's unlocked? Seems mine unlocks/locks properly but doesn't pop open when I press it in on the middle of the right side.
Old Oct 3, 2021 | 01:26 PM
Maxpowers's Avatar
Maxpowers
The lock has been known to fail. If you cant pry it open with an interior plastic trim tool, I bet your lock motor failed. Lots of threads on how to fix if you search.
Old Oct 3, 2021 | 04:15 PM
joemessman's Avatar
joemessman
Have a look at this tread.
https://www.corvetteforum.com/forums...-not-open.html
Old Oct 3, 2021 | 08:41 PM
Thankfully mine has not failed to open. But thanks for the link to the thread above.
Old Oct 3, 2021 | 11:56 PM
Avanti's Avatar
Avanti
One of the first things I did when I got my new '18 was block off the lock-pin hole so it will not lock. However, reading the OP's post it seems his/her issue is not necessarily that the lock has failed, but the actual "push-release" mechanism has. That I've never seen before, but if it's installed on a car it certainly can fail.
Old Oct 4, 2021 | 05:42 PM
Zjoe6's Avatar
Zjoe6
You can buy that mechanism and it's not that expensive. If it's under warranty or extended service plan, it should be covered.
To Gas door question
