Hesitation
Old Oct 15, 2021 | 12:04 PM
Buckner21's Avatar
Buckner21
Default Hesitation
Has anyone experienced a hesitation when the car is in park at idle and you crack the throttle quickly and it sounds like it's sucking air? When I crack the throttle it's not a quick crisp throttle, there is a gasp of air before it revs up. Any particular reason why?
Old Oct 15, 2021 | 12:21 PM
beaversstonehaven's Avatar
beaversstonehaven
My last two C7's did that. I think it it normal.
Old Oct 15, 2021 | 12:24 PM
Dcasole's Avatar
Dcasole
Drive by wire is not like the old days where you had a mechanical one to one connection between the gas pedal and the throttle blades of the carburetor. When u snapped the pedal the carb instantly opened and to cover that big gulp of air the accelerator pump had to squirt a big shot of gas
The abridged and simple explanation is Drive by Wire on a C6 and a C7 has a slow throttle body opening ramp and then a much quicker rampup the farther the pedal is pushed . GM also caps the max RPM you can attain when in neutral or park
PM me if you would like a detailed explanation
Dave
Old Oct 15, 2021 | 12:31 PM
kenownr's Avatar
kenownr
Old Oct 15, 2021 | 12:33 PM
C7&7's Avatar
C7&7
Totally normal.
Old Oct 15, 2021 | 12:35 PM
Buckner21's Avatar
Buckner21
Thanks guys, I didn't know if this was normal or something that needed looked at👍
Old Oct 15, 2021 | 12:41 PM
Dcasole's Avatar
Dcasole
No Problem. Perfectly Normal 👍
Dave
To Hesitation
