Cold Storage or Heated Storage?
I also have to reserve 2 weeks in advance to store it and reserve 2 weeks in advance to get it out. That means I might be bringing it dirty from slush or snow and won't be able to put a cover on it or miss out 2-3 weeks of driving if I bring it in early...
If I store it at home some days where it gets a little warmer I notice everything that's metal inside the garage gets wet from condensation. From what I read about cold storage from other threads winters aren't as cold south of the border and I wonder if it will get more rust leaving at home? I don't have room for a car bubble and heating the garage would cost more than the storage place.
What would you guys do?
Usually it's a combination of the car getting (relatively) cold, and then warmer but more humid air moves into the area. The car parts haven't warmed up yet and they condense the moisture out of the air like outside a glass of cold water on a warm summer day. After a day or so, the car slowly warms up and/or the local air becomes dryer and the condensation disappears
The glass & plastic parts of your car don't care about moisture. The painted aluminum parts should be ok. The bare aluminum will eventually tarnish or speckle some, but it's only an appearance issue and much better than driving on the salted roads like many people do.
I don't know how good or bad the price is on your previous place, but the quality certainly sucks.
I'd wash your car cover thoroughly, leave the windows open an inch or two, and follow whatever you think best about the other suggestions.
Use a battery tender and look at it every few days to make sure the connection in the trunk is still good, sometimes they come loose for no reason.
See you in the Spring!
I had hip replaced before Christmas and could not drive anything let alone the really hard to get into and out of c7. I had some one start it and run for 10minutes to get things flowing and warmed once a week. I figured my house generator runs once a week on Tuesday morning at 10am automatically and so the vette, Mustang and truck could be handled the same. I would be more of a nut case than I am if I had to not drive these things every winter for months at a time?
I am back driving but still no easy task getting in or out of vette or Mustang? Damn hip!
good luck to all those up north
If it's any consolation check this out, If you can get in great!
