Trunk release help!
Old Oct 22, 2021 | 06:58 PM
Stratic's Avatar
Stratic
4th Gear
Default Trunk release help!
Looking for some help! I’m replacing my battery and the old is removed. When I returned with the new one and went to pop the trunk manually through the key above the license plate the trunk does not pop open. I’ve tried both keys out of both fobs and used some plastic pry pieces but this thing isn’t opening. Anyone have suggestions??
update from post below: yes, I’ve tried to turn the key very hard. I can hear a slight sound of a latch or cable moving but it doesn’t release the trunk. I’ve tried pushing down to reset the latch and with 2 people, one turning while I try to pry up with some plastic tools, no success.
I was told there’s poles under the hood to jump start the car but the hood release is inside and the doors are locked. Someone else said I can jump the starter but I haven’t found info on exactly how to do that.
Anyone know how to release or gain access to the hood or door cable? Would need to confirm I can jump the car from under there too. Or maybe a secondary release for the doors somewhere?? All out of ideas on my end, thanks in advance for any help!
Old Oct 22, 2021 | 07:41 PM
RonC7's Avatar
RonC7
If the key turns real easy you are in trouble - the cable is likely disconnected.
The key should feel hard to turn, almost hard enough that you are afraid of breaking the key. Pushing down on the hatch above the latch may make the key a bit easier to turn. Yearly lubrication and testing is a good idea.
You can connect 12 V to the stater just inside of the front wheel to get enough voltage to operate the locks. There are several threads showing where to connect.
No, the connections under the hood are not adequate for jump starting the car, but are good enough to charge the battery or apply voltage to operate the locks.
GL
Ron
Old Oct 22, 2021 | 07:42 PM
DrivesWithTwoFeet's Avatar
DrivesWithTwoFeet
Not trying to be a smart *** but try turning the key a little further.
Old Oct 22, 2021 | 07:50 PM
Stratic's Avatar
Stratic
4th Gear
Thanks but I don't think I can force it much more without breaking the key off.
Old Oct 22, 2021 | 07:52 PM
Stratic's Avatar
Stratic
4th Gear
Thanks Ron, I'll research how to access that 12V stater and hope that works! FYI: its not very difficult to turn the key for the release. A buddy sent the specs for the manual trunk release and it looks like one cable from the key fob goes into a box and then triggers the large release spring. I feel like that has come loose or is broken altogether. Appreciate the advice!
Old Oct 22, 2021 | 08:27 PM
RonC7's Avatar
RonC7
I can't find the thread quickly, but I did save the picture from a thread showing where to connect on the starter. You may need to remove the right front wheel. Be sure to use a jack stand or blocks if you get under the car. Never trust a jack!
See attached:
Ron
File Type: pdf
Old Oct 24, 2021 | 02:18 PM
c5arlen's Avatar
c5arlen
Yet another disign flaw by General Motors... What a pain we must deal with and them.
Old Oct 24, 2021 | 03:00 PM
AZRenegade's Avatar
AZRenegade
I would say this is more of a maintenance issue than a design flaw. In the event of a loss of power the engineers provided access via a key lock. The first thing I did when I purchased my Vette was to check all of the emergency systems to ensure that they worked. Besides, why would you lock the vehicle down and close the trunk when changing the battery? It's obvious that you wouldn't be using the vehicle to run to the store to get the new one. with the old battery removed. One other thought for the OP. Unless you are the original owner, are you sure that you were issued the correct keys?
Old May 10, 2022 | 02:51 AM
C7jeo's Avatar
C7jeo
Cruising
GL
Ron
hey ron i have the same problem except my batter isnt dead. Looks like the previous owner i bought the car from did not connect the cable when installing a new bumper and now i dont know how to open the trunk. I tried manually opening and everything with key fob. Any ideas?
Old May 10, 2022 | 08:07 AM
Dennis Bernal's Avatar
Dennis Bernal
This is 100% not a design flaw, this is a unique situation where the counter measures have apparently been disabled.
If it is true that the cable has been disconnected, you are much more likely to have luck trying to power the system back up enough to energize the lock cylinders.
Once you solve the issue, be sure to put in the extra work to get that cable hooked up again. Good luck. Hope the starter hook up idea above does the trick.
Final "note to self" leave window down at very least if you are going to remove battery and close doors, hatch and hood. Best probably to leave all things cracked ajar in this odd situation.
Old May 10, 2022 | 09:21 AM
RonC7's Avatar
RonC7
C7jeo
I SEE YOU STARTED ANOTHER THREAD THAT STATED "BUTTON WAS DISCONNECTED BY PREVIOUS OWNER". You should have included this info in post above.
C7jeo - if your door locks work and other electrical stuff works, will the car start? A running car should assure full voltage. The hatch should open from the dash button, rear button near the license plate, or fob. Try pushing down or pulling up a bit on the hatch when you push a button. If the buttons or fob won't open the hatch with the motor running then you probably have a latch or electrical issue.
Also note that fob batteries should be replaced about every 3 years with good, fresh batteries that measure above 3 volts. Not likely your issue at this time, but good to know.
GL
Ron
Old May 10, 2022 | 10:24 AM
SounderMN's Avatar
SounderMN
C7jeo
GL
Ron
C7jeo wasn't the thread starter. His was a different issue.
Old May 10, 2022 | 03:17 PM
C7jeo's Avatar
C7jeo
Cruising
C7jeo
GL
Ron
I recently purchased a 2017 c7 grand sport. The previous owned mentioned to me that he is tall and fisconnected the trunk because he would accidently hit the trunk button often.
now ive been trying to open the trunk because my logic is if my battery dies one day i wont be able to open my car at all.
ive tried manually opening it with the key on the back on the car but it does not open. I have been trying to find a way to open it but cant find any other way to do so.
i also decided to remove the entire back bumper to connect the trunk back but in irder to remove the rear bumper i have to have the trunk open.
anyone have any ideas what to do? My battery hasnt died yet but if it does i wont be able to open the car at all because in order to open the front door the latch is in the trunk from my understanding.
Old May 10, 2022 | 09:13 PM
RonC7's Avatar
RonC7
There are 2 fuses in the rear fuse block labelled Trunk release module & Trunk release module latch (fuse numbers change year to year - look in owner's manual) that may need checked - of course you need to open the rear hatch to access...
Does the key turn easy with no resistance? Probable cable issue.
Does the key turn hard - afraid of breaking the key? Normal, need to turn 60 degrees or so. Push down or pull up on the hatch. Lubricate lock with graphite, weather strip with rubber protectant..
Ron
Old May 11, 2022 | 12:05 AM
@Stratic I know this is an old thread, but what did you come up with as a solution to your trunk not opening? Please post up what happened.
To Trunk release help!
