Depends if you are looking for a tender or a charger/tender. I use the Genius G3500 which does both. 3.5amp charging rate then trickles. Great product.
Pretty much any trickle charger will work regardless of the brand. I have a c-tech one thats non GM branded and it works just fine.
Not really. There's a big difference between a trickle charger and a smart charger...
Trickle chargers provide slow/steady charge, but never shutoff, so they're prone to overcharging.
Smart chargers automatically switch between multiple modes to optimize the life of several battery types (e.g., Wet, MF, AGM, GEL and Ca) without the risk of overcharging.
If you're running CTEKs, you have smartchargers, not trickle-chargers.
