Street driving without traction control
Old Dec 8, 2021 | 03:44 PM
  #41
JMII's Avatar
JMII
Originally Posted by Elk
My suspicion is your rear tires are in fact actually spinning.
My guess - the rear tire size is different then OEM thus confusing the TC system. There is a F-to-R ratio that has to be maintained, if you run a taller or shorter rear tire (like many drag racers do) that messes things up.
Old Dec 8, 2021 | 03:45 PM
  #42
sstonebreaker's Avatar
sstonebreaker
Very interesting.
I expect traction control compares the speed of the rear tires to the fronts to determine whether the rears are spinning. Thus, it does not matter how the fast the car accelerates for traction control to kick in, only that the rears are spinning faster than the fronts. My suspicion is your rear tires are in fact actually spinning.
Like I said, the drag radials like a little tire spin, so that's certainly possible, particularly on an unprepped surface. What I do know is that the car will run nearly 3/4 second faster at the track with the traction control turned off, and with the amount of VHT they put down, I doubt the tires are spinning even a little bit.
Old Dec 8, 2021 | 03:50 PM
  #43
sstonebreaker
Both the front and rear tires I have on the car are about 3/4 of an inch taller than stock, so that variable shouldn't affect things much. Something to think about though.
Old Dec 8, 2021 | 04:07 PM
  #44
Elk's Avatar
Elk
Originally Posted by sstonebreaker
. . . with the amount of VHT they put down, I doubt the tires are spinning even a little bit.
That stuff is amazing for grip - as long as it does not get wet.
Old Dec 8, 2021 | 08:00 PM
  #45
GTS Bruce's Avatar
GTS Bruce
Had a viper 550 ft/lb tq. no nannies. Made me real careful. Some fishtailing on the street once in a while teaches you to get out of it.Spun a couple of times on a track.I would never turn off everything street or track. I like the fact that the car can help save my azz.
Old Dec 8, 2021 | 08:26 PM
  #46
fumbling's Avatar
fumbling
Originally Posted by Jeremie Fischer
I've had instances where accelerating quickly it activates in a way that I'm not particularly fond of. I can manage light tire spin without losing the car and don't need the computer to intervene in those situations.
I know that if I just mash the loud pedal the car will get out of shape faster than I can recover it, that's why I leave the stability control on at all times now. With the TC off the tires will spin as long as the car is still pointed straight, if the back end starts to come around the stability control jumps in and corrects things. This allows me personally to have the most fun with my car.
With my 2017 M7, I never turned TC off for the first 3 years but then out of curiosity tried TC off but with SC on, and spun the tires accelerating from 1st gear for the first time, but still able to stay in my lane. That was so fun compared to keeping TC on with no wheelspin, so these days I always turn TC off and when conditions are safe, I enjoy some fun wheelspin while still keeping the SC on. I couldn't spin the wheels in any car I've ever had before, so IMHO it's a lot of fun and relatively safe in the C7 to keep TC off.
Old Dec 9, 2021 | 07:23 PM
  #47
Mad*Max's Avatar
Mad*Max
Originally Posted by Submerge
How often, if ever, do you turn off just traction control while doing normal street driving? I have the seen the videos of C7’s getting very squirrely if you accelerate and turn the car in an “unbalanced” condition. This was drummed into us at the Ron Fellow Driving School.
I think we get used to the traction control and would be wary turning it off, especially on the street.
Thoughts appreciated.
I can't control the car with everything on and on warm dry pavement, so no never turn it off.
Old Dec 15, 2021 | 02:02 PM
  #48
STALION's Avatar
STALION
From: ALL governments are legalized mobsters, so doesn't matter where I live :(
Originally Posted by jdvann
I love my car more than my ego...so never.
Jim
THIS!
I used to track my C5 heavily, and a few times in the C7 and if you don't know what you're doing it will be very easy for the car to get away from you. Proof of that all over youtube, and there is no way I want to be a potential highlight reel.
Old Dec 16, 2021 | 03:33 PM
  #49
rightrudder's Avatar
rightrudder
Same here...ups the fun quotient.
Actually it was quite frustrating at first because my '14 Stingray (which I bought about a month ago) had the original 8-year-old MPSS ZPs, so fossilized that they had next to no grip, and an incredibly small window between adhesion and wild wheelspin when getting into the throttle aggressively.
New tires made all the difference. Got me some fresh Goodyear Eagle F1 Supercar 3s and the car is vastly more fun.
Old Jan 3, 2022 | 12:30 AM
  #50
rb185afm's Avatar
rb185afm
I ran without TC religiously. You better know what your doing. The C7 has a snap point. Good to understand it before turning off TC. I advise doing a drift school to safety find it and understand it. Not a good idea to experiment on the street, if you’ve never spun under throttle. When it happens, it goes fast!
Old Jan 4, 2022 | 09:49 AM
  #51
v.vet's Z06's Avatar
v.vet's Z06
I leave the TC on all the time. Yes, I have been to Ron Fellows driving school - twice. There is much to learn with these great cars. Having choices reminds me of the days when we did not have those choices - the 60s. Driving GTOs, Chevelles and GTXs on the streets were a handful and driving in the snow, because you had to, was borderline crazy. We had no idea how good we would have it in 2022!
Old Jan 4, 2022 | 10:06 AM
  #52
Submerge's Avatar
Submerge
Traction control in high horsepower cars is like turning a high spirited bucking bronco into a much tamer saddle horse. The Soler TB and throttle controller takes you a little to the wilder side, but still in control with traction control on. I will turn it off when I find a nice open area with no light poles or other things to run in to if it gets dicey.
At the Ron Fellows school we were always in Track Sport Mode, so still had some traction control.
