Throttle response
Old Dec 8, 2021 | 10:38 AM
Buckner21's Avatar
Buckner21
Default Throttle response
Hey guys any help would be appreciated. I have had Kooks longtube headers and offroad X-pipe put on and a standard street tune in my 2016 C7 stingray back in October, I just put a Solar Throttle Response on this week. It ran great and responded great for 1 day, the next day I cranked it up and it went into limp mode. Any suggestions? Should I recalibrate it and try it again or just leave it off? I don't won't to have to worry Day to day about it sending codes and going into limp mode. Thanks in advance.
Old Dec 8, 2021 | 12:28 PM
Scoobydoobydoo's Avatar
Scoobydoobydoo
If you bought it new call Mike at Soler Performance. He'd be the best guy to get advice from.
Old Dec 8, 2021 | 01:59 PM
jimmbbo's Avatar
jimmbbo
Had a similar problem earlier this year. Emailed Mike and he sent a replacement unit pronto, and haven't had a glitch since... Mike is on the short list for the best customer service on the interwebs...
Till then, just remove the TC and suffer with the tip-in flat spot
Old Dec 8, 2021 | 02:50 PM
Avanti's Avatar
Avanti
Did you actually take the device off, wipe any codes, and try again. It may be a quirk that the two events occurred together... or not. You don't know otherwise. All the best.
Old Dec 8, 2021 | 03:16 PM
Rayland's Avatar
Rayland
Banned Scam/Spammer
OP:
Occam's Razor: Is a philosophical tool for 'shaving off' unlikely explanations. Essentially, when faced with competing explanations for the same phenomenon, the simplest is likely the correct one.
Many thanks,
Ray
Old Dec 8, 2021 | 03:55 PM
spoolin03's Avatar
spoolin03
I actually hated my throttle controller. It messed with the automatic transmission.
Old Dec 8, 2021 | 03:56 PM
spoolin03's Avatar
spoolin03
But it did teach me that all I had to do was mash the pedal a little to get the kind of output I need
Old Dec 8, 2021 | 04:00 PM
andybbbb's Avatar
andybbbb
Same thing happened to me and Mike sent me a new one after I returned faulty one. Great customer service. Call him and he’ll take care of you.
Old Dec 8, 2021 | 04:46 PM
Buckner21's Avatar
Buckner21
I have wiped codes and I think I will try recalibration again and see if that works, if not, I will contact Mike. 👍
Old Dec 8, 2021 | 09:40 PM
^ give it a try. If it doesn’t improve, contact Soler. My TC works great.
Old Dec 9, 2021 | 02:48 PM
WPGZ06's Avatar
WPGZ06
What did you not like about it?
Old Dec 9, 2021 | 02:58 PM
2ZORNOT2Z's Avatar
2ZORNOT2Z
Did you have the trans tuned (TCM) along with the ECU when you put the headers on? If so the Soler TC may be conflicting with the changes to the stock trans tune. If they didn't touch the TCM then I agree with what the others have posted above about calling Soler for a replacement.
Old Dec 9, 2021 | 04:17 PM
spoolin03's Avatar
spoolin03
I pay very close attention to the car's behavior. Mechanical things these days seem to have self-adjustability through computer management based on input. Before the throttle controller, I liked the shifting of the transmission - it was firm but comfortable. With the throttle controller, the increased throttle input makes the TCM think that I'm driving aggressively, and so will pull out the map for aggressive/rough shifting. I'm not a fan of this mode, as the shifts are harsh and it feels like the transmission is getting worn out faster. With the throttle controller, my car was stuck in the aggressive shifting pattern 24/7. I decided to pull it out and the car returned back to 'normal' or how I preferred it. Your mileage may vary.
Old Dec 9, 2021 | 04:18 PM
spoolin03's Avatar
spoolin03
I don't think the TCM can be tuned...
Old Dec 10, 2021 | 09:21 AM
2ZORNOT2Z's Avatar
2ZORNOT2Z
It absolutely can on an A8. Transmission shift points, pressures, etc... can all be massaged. You wouldn't need that done just for a header install but some tuners pad their pockets with it and some owners ask for it thinking they need it. Higher HP cars or cars that are used on the strip a lot can benefit from it.
Old Dec 10, 2021 | 11:58 AM
WPGZ06's Avatar
WPGZ06
Understandable. Thought you were saying the product was no good, which I'd disagree with, but you simply prefer oem shift points which is fair.
Old Dec 10, 2021 | 01:54 PM
jimmbbo's Avatar
jimmbbo
FWIW IIRC Mike indicated that the TC was misreading the TB idle setting incorrectly... Assuming a solid design, it sounds like a QC glitch affecting a small number of units.
To Throttle response
Old Dec 10, 2021 | 02:10 PM
c5arlen's Avatar
c5arlen
Right on!... Learn to drive a Corvette as designed!... The designers aren't as dumb as they sometimes appear.
Old Dec 10, 2021 | 02:26 PM
spoolin03's Avatar
spoolin03
what really? I thought TCMs were guarded by the industry against tinkering. Why are tuners acting like I’m asking for national secrets when I want them to change transmission characteristics on my infiniti?
Old Dec 13, 2021 | 05:05 PM
jaiyenyen's Avatar
jaiyenyen
Did you try different settings on the throttle controller, one setting is the same as stock and you can go up from there. Of course if you have it set at a higher setting it will behave differently.
