Rough idle/vibration/normal?
Old Dec 16, 2021 | 10:21 PM
Catfish4818's Avatar
Catfish4818
Default Rough idle/vibration/normal?
We've had our 2015 Z51 only since last Friday. 8-speed automatic; it's a great car - we love it. At idle (600-700 rpm) there's a slight shake to the car from the engine. I don't know enough about the car to know if that's normal or not. The car has only 13,000 miles, so I'm ruling out any high mileage condition. So is what I'm attempting to describe normal?
TIA,
Larry
Old Dec 16, 2021 | 10:33 PM
Elk's Avatar
Elk
Normal.
A rougher idle signals "performance" for many and GM takes advantage of this.
Old Dec 16, 2021 | 10:36 PM
Mad*Max's Avatar
Mad*Max
Normal
Old Dec 16, 2021 | 11:18 PM
jdaniels138's Avatar
jdaniels138
Veteran: Marine Corps
Yep! It's just letting you know it's ready to run ...
Old Dec 17, 2021 | 03:05 AM
jimmbbo's Avatar
jimmbbo
It's performance waiting to get out...
Old Dec 17, 2021 | 06:18 AM
Catfish4818
Thanks, guys! I was sort of wondering if the answer was 'yes, this is what 460 horsepower feels like'.
Larry
Old Dec 17, 2021 | 08:58 AM
Yes, a slightly rough idle is perfectly normal. Been that way since at least the C5 generation.
Old Dec 17, 2021 | 09:06 AM
Travlee's Avatar
Travlee
the thing i love about my car is the cam booty shake...
my c6 had a mild shake, the c7 makes me feel like Shaq in his shoulder shake gif
Old Dec 17, 2021 | 09:08 AM
Catfish4818
Yep, I'm a fan of the shake, too. As long as I know that it's not there because something's wrong.
Old Dec 17, 2021 | 10:02 AM
JMII's Avatar
JMII
I thought I read once the GM engineered the idle to be a bit lumpy. They could have made it run smoothly but people expect a V8 to rumble and shake a bit.
Old Dec 17, 2021 | 11:39 AM
Elk's Avatar
Elk
This is exactly the case. GM built the gentle lope into the idle to push enthusiasts' buttons.
The gentle irony is the idle is actually so smooth anyone who has driven or even sat in a car with a serious cam will not even vaguely notice a stock C7's idle. The C7 idle "shakes" only in reference to a buttery smooth BMW or Cadillac.
Old Dec 18, 2021 | 03:02 PM
Skid Row Joe's Avatar
Skid Row Joe
TIA,
Larry
Take it to a Chevrolet dealer and have it checked out. You have no idea how the car was driven in the preceeding 13K miles.
Yes, they shake/vibrate @ idle. One thing that may smooth it out is adding a bottle of Techron to a 12 gallon fill from near empty. Do this 3X a year.
Old Dec 18, 2021 | 03:06 PM
Skid Row Joe
Links to your claim?
Old Dec 18, 2021 | 03:32 PM
Catfish4818
I have a Tues AM appt at the local Chevy store for a check up, not so much for this though I will ask about it, but rather to have them look for any issues that should be covered by CarMax's 30 day warranty. If they find something wrong, CarMax will fix it. After the 30 days are up, I've purchased CarMax's extended warranty (60 months) with a $300 deductible that I'll use in the event of any $$$$ repairs.
Old Dec 18, 2021 | 06:29 PM
jimmbbo's Avatar
jimmbbo
Some say the LT1's shaking is an improvement over the thrashing machine noise of an old school small block with a Duntov 30-30 cam where the solid lifter valve lash was set to .030 inches, creating a clattering that announced the car's arrival well in advance... Dunno... sounds sweet to me!
Old Dec 18, 2021 | 06:44 PM
fumbling's Avatar
fumbling
If you're at the dealer and they have another C7 on the lot and are willing to start it up for you, you could compare your idle "shake" to the C7 on the lot. I also have the idle shake and rumble. I took the Ron Fellows owner's class and every C7 I drove there also had the slight idle shake. I enjoy the rumble at idle, part of the car's character, just like the cold start sound.
Old Dec 18, 2021 | 10:04 PM
Catfish4818
I'm not bothered at all by the shake/rumble. Just want to make sure it's not a sign of something amiss.
To Rough idle/vibration/normal?
Old Dec 19, 2021 | 12:35 AM
Elk's Avatar
Elk
Your car is completely fine.
But if you remain concerned, have it checked out. It is not worth worrying about it and taking the fun out of driving the car.
Old Dec 19, 2021 | 07:38 PM
Frid's Avatar
Frid
St. Jude Donor '21-'22
The wiggle makes me giggle. Just the power behind the heart of the car
Old Dec 21, 2021 | 12:23 AM
SD_Dave's Avatar
SD_Dave
Dr. Dave
The idle mixture is set lean by GM. That’s a big reason for the rough idle. It can be smoothed out a lot with a programming change to increase the mixture and the idle rpms.
