Build sheet location?
Old Dec 21, 2021 | 08:03 AM
Catfish4818's Avatar
Catfish4818
Default Build sheet location?
On our 2015 I've pulled the rear compartment cover up far enough to find the SPID label. If I keep pulling, am I likely to find the build sheet (assuming a previous owner hasn't already done so)? The car appears very unmolested with only 13,000 miles. Or, if that wasn't where GM placed the sheet, where should I look? I'll be ordering the window sticker from the Corvette Museum and will add the build sheet to the order if needed.
Thx!
Larry
Old Dec 21, 2021 | 08:12 AM
jimmie jam's Avatar
jimmie jam
I'm under the impression that build sheets have not been put in Corvettes for a long time ...
Old Dec 21, 2021 | 09:44 AM
Jeff V.'s Avatar
Jeff V.
That's not true. The factory puts them in the car with the accessory bags. Problem is, a lot of dealers or first owners then toss them out.
There's no secret stash in a frame rail or under a trim panel.
You can order some kind of after-the-fact build sheet from the museum, but it's nothing like the sheets that go down the line with the car.
Old Dec 21, 2021 | 10:49 AM
Maxpowers's Avatar
Maxpowers
I asked my dealer to keep them and the passed it along to me.
Old Dec 21, 2021 | 10:52 AM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
1984, 1985 White sticker located on the underside of the rear, left storage compartment cover (on the driver side) of the car.
1986, 1987, 1988, 1989, 1990, 1991, 1992, 1993, 1994 White sticker located on the underside of the center console lid.
1995, 1996 White sticker located on the underside of the rear, right storage compartment cover (on the passenger side) of the car.
1997, Early 1998 White sticker located on the underside of the rear, left storage compartment cover (on the driver side) of the car.
Late 1998 - 2013 White or silver sticker which is located inside the glove box compartment on the glove box door.
2014, 2015, 2016, 2017 Silver sticker which is located under the rear compartment carpet, near the battery.
2018, 2019, 2020 GM completely revamped the RPO Code sticker. They moved the silver sticker to the driver-side door and added a QR Code. The RPO Codes can only be read using a QR Code scanner.
https://corvettesalvage.com/how-to-s...our-rpo-codes/
Elmer
Old Dec 21, 2021 | 01:58 PM
Catfish4818
Thanks, guys. Looks like I'll get the copy, or reasonable facsimile thereof, from the museum!
Old Dec 21, 2021 | 02:30 PM
Let It Ride's Avatar
Let It Ride
These are what the real build sheets look like from the factory. I'm telling you, you will not be happy with what you get from the museum.
Old Dec 21, 2021 | 02:58 PM
Catfish4818
Hmm...OK, I believe you. Does anyone have a pic of a museum build sheet to share?
Old Dec 21, 2021 | 03:19 PM
CB56's Avatar
CB56
Go to your dealer and have them print you a build list. It won't be like the one posted above but it will tell you all the standard and options that are on your car.
Old Dec 21, 2021 | 03:26 PM
Catfish4818
Ah; I had no idea they could do that. Thanks!
Old Dec 21, 2021 | 04:57 PM
eboggs_jkvl
Moderator emeritus
This is what you get from the museum. It is heavy plastic coated.
Elmer
Old Dec 21, 2021 | 05:02 PM
Catfish4818
Elmer
Great; thx, Elmer!
Old Dec 21, 2021 | 05:35 PM
Jeff V.'s Avatar
Jeff V.
Elmer
Gotta pay extra for for the lamination. Mine was just plain paper.
Old Dec 21, 2021 | 05:41 PM
Let It Ride
All you are really getting from the museum is a option list of what your car has, has nothing to do with what a build sheet tells you.
Old Dec 21, 2021 | 06:37 PM
Those would be very nice to have, but unfortunately I bought my car used and they were not with the car. Who knows if the original owner even got them. But the Museum sheet is the next best thing.
Old Dec 21, 2021 | 07:16 PM
Avanti's Avatar
Avanti
When I picked up my '18 from Kerbeck's I found a bunch of factory paperwork under the passenger seat.
Old Dec 21, 2021 | 07:53 PM
RMS73's Avatar
RMS73
You can recreate the build sheets as used on the assembly line if you have enough time and printer paper.
Let it Ride sheets are not the same for the early C7.
To Build sheet location?
Old Dec 22, 2021 | 09:51 AM
Jeff V.'s Avatar
Jeff V.
Yep. Build sheets changed in 2018 when they overhauled the assembly line.
Old Oct 5, 2025 | 08:54 PM
TKOVETT's Avatar
TKOVETT
Help,
Looking on buying 2017 Z06 LZ1 would like to know if I could get the build sheet or window sticker buy the Vin number?
Any help would be greatly appreciated. "1G1YP2D69H5601875"
Thanks,
Old Oct 6, 2025 | 06:18 AM
Catfish4818
Originally Posted by TKOVETT
Help,
Thanks,
Go to this site https://monroneylabels.com/, enter the VIN, pay $10, and you'll IMMEDIATELY be emailed a PDF of the info that had been on the window sticker. It won't be a duplicate of the sticker (get that from https://www.corvettemuseum.org/ for about 100 bucks), but it will list all the options and prices. Cheap research if you're considering the car. Good luck.
The Monroney label will look like this -
