Spark plug and plug wires
I've got 60,000 miles on my 2016 c7 stingray. I'm Fixing to put new plugs and plug wires in. Should I go back with the factory plugs and wires or are there better ones out there i should try?
Original plugs and wires lasted 60k for you, so get another set of OEM wires and plugs. I see no reason for aftermarket in this case.
Artarmy (05-17-2024)
Received 3,448 Likes
I thought the plugs on a Stingray were good for 100K?
97,500 miles LT1
LT4 60,000 miles
LT4 60,000 miles
The following 2 users liked this post by Elk:
Bayshore Vette (12-28-2021),
joemessman (12-26-2021)
Received 19,838 Likes
'20-'21-'22-'23-'24
Nothing wrong with the OEM plugs and wires. Curious why you are changing at 60K miles - having performance issues?
Received 2,077 Likes
St. Jude Donor '13
One data point:
On the C6, a local dealer tech said that the plugs don't need replacement at 50k miles, but at 100k miles they definitely do need replacement.
For a C7, many don't drive it as much so it make be a while before replacement. Problem is the plugs are expensive. On my C4, I loved the cheap copper plugs. Toss every year with the cap and rotor. No issue with it freezing up in the head. My diesel MB had issues with the glow plugs. Annual plug R&R with the bore brushing of the prechamber solved sticking plugs. On another vehicle, I had no issues with the 100K plugs. I did gain some mpg by changing the plugs at 70K although they were "good" to 100K.
Unless there is something wrong or you are doing something exotic, I would agree with you. Same as indexing the plugs. For Rock Auto, I really can't afford them. Sure, they are financially less expensive but the aggravation when dealing with them doesn't make it worth while. As long as the parts are right and don't need warranty, the price can be beat but not easily. At this time, I won't buy anything from them I can't afford to throw away and buy another if there is an issue.
Received 4,859 Likes
Totally agree with the above posts, go with OEM replacements
KemahGT (12-28-2021)
2016 Z06 and Dealer says plugs fouled
13,000 some odd miles on my 2016 Z06 and it started missing after winding it up a few times, took it to the dealer and he said several cylinders have been missing a lot, said I need new plugs and wires!?! And I hear 50,000 to 90,000 miles on plugs, anyone else having this problem?
St. Jude Donor '13
