Dead Car Battery
Old Jan 7, 2022 | 07:28 PM
CorvetteFanaticMan's Avatar
CorvetteFanaticMan
2nd Gear
Default Dead Car Battery
Hi Everyone, I have a dead battery on my 2019 Corvette Grand Sport. Will the trickle charger be enough to get me going again or do I need a jump starter box like maybe the NOCO Boost XL GB50 1500. I replaced the battery in the Key Fob just in case that was the problem but still won't crank. I don't drive it much.
Old Jan 7, 2022 | 08:03 PM
seniorstorekeeper's Avatar
seniorstorekeeper
If the battery is completely dead, it will probably take more than a jump box to start it. I would take a regular battery charger, not a trickle charger and put the battery on charge for a day or so and see if it comes back. The battery charger I have has a 50amp starting setting, a 10amp setting and a 2amp setting. I would probably hit it with a short 50a cycle, then set it on 10amp and let it charge a day or so and see if it has any life left in it.
Old Jan 7, 2022 | 08:07 PM
VinceC5's Avatar
VinceC5
Take your battery to Autozone, they will charge it overnight.
Old Jan 7, 2022 | 09:57 PM
Mad*Max's Avatar
Mad*Max
I have a battery tender with a 4A setting and charging for several hours on that setting does the job, assuming the battery is not defective.
Old Jan 7, 2022 | 10:07 PM
ogrick's Avatar
ogrick
3rd Gear
This 100%. Had this done once and they charged it overnight for me.
Old Jan 7, 2022 | 10:32 PM
jimmbbo's Avatar
jimmbbo
If the battery is totally dead, a trickle charger will be of little use. A jump battery likely will start the car, but am unsure how the electronics behave after start with a completely flat battery. Getting the battery checked by AutoZone makes sense, and based on it being only three years old the battery shouldn't have died, so plan on buying a new one.
One caution is that if you bought the car used, it may have sat untended for some time, which is death on battery life.
Old Jan 7, 2022 | 10:43 PM
Kevin A Jones's Avatar
Kevin A Jones
Fully charge your battery with a battery charger prior to starting your car. Your C7's alternator is more for keeping a battery charged as opposed to completely charging it. Using your alternator as a battery charger can blow the diodes.
Old Jan 7, 2022 | 11:24 PM
This makes a lot of sense. If they can't get it to charge properly, be prepared to just buy a new one.
Old Jan 7, 2022 | 11:50 PM
Tommy79's Avatar
Tommy79
Go buy a new one... Problem solved.
Old Jan 8, 2022 | 07:44 AM
Tinkertech's Avatar
Tinkertech
Fully discharged batteries < 3 - 4 volts don't like to be charged at a high rate. It can warp the plates inside the battery.
It is usually best, if you have the time , to start at a lower charge rate ~ 10 - 15 amps. A long charge is your best bet to recover a badly discharged battery.
Old Jan 8, 2022 | 09:06 AM
Kevin A Jones
That's correct!
Personally, I wouldn't leave my battery somewhere to charge that is in business to sell batteries.
Old Jan 8, 2022 | 09:25 AM
Zjoe6's Avatar
Zjoe6
If you have the factory battery tender I would try and plug that in for a few days and see it charges.
Old Jan 8, 2022 | 09:29 AM
dvilin's Avatar
dvilin
I agree with Tommy79 just buy a new battery.
Old Jan 8, 2022 | 09:52 AM
Kevin A Jones
Might be a good idea, but I'd be more concerned with what completely drained a Delco battery that's most likely less than 3 years old. Same thing may happen to a new battery.
Old Jan 8, 2022 | 11:12 AM
Maxpowers's Avatar
Maxpowers
I too agree to replace the battery. A dead one is never the same.
Old Jan 8, 2022 | 12:36 PM
duckvett's Avatar
duckvett
2023 C7 of the Year Winner - Unmodified
2018 C6 of Year Winner
I am dealing with this same scenario on a friend's `19 GS. He is having some serious health issues and the car sat outside for several months. We were able to jump-start the car and move it back into the garage. Let it run for approximately 30 minutes, but the electronics were FUBAR. A battery tender brought the battery up enough that it would start, but windows would not re-index, trunk won't open and DIC messages won't go away. He finally decided to just buy a new battery (even though this one is only 18 months old) and see if that solves the issues. Now to find that battery tender....
Old Jan 8, 2022 | 01:28 PM
orca1946's Avatar
orca1946
Does Auto Zone know how to change our batteries correctly?
Do they have a very good battery to replace ours?
To Dead Car Battery
Old Jan 8, 2022 | 01:50 PM
Mad*Max's Avatar
Mad*Max
They only do simple battery changes, when my LaCrosse needed a new battery in an emergency situation they refused to change it, the C7's change is slightly more complicated due to its location.
Old Jan 8, 2022 | 03:33 PM
aklim's Avatar
aklim
They will do battery changes but not if you have to remove the fender cover or take apart a bunch of stuff to get at it. Some will not want to do a battery change if there is an ECM sitting on top for liability reasons. For my C4, you will have to take the plastic panel out. NFW would I ever do that for anyone but myself. If that panel cracks, your fault, my fault or nobody's fault, you will have to buy a remake, take the bracing off the old one, prep and paint the new one and install the bracing. Mine broke. Not sure if it was me or the PO but it was broke at the bottom. The safest way to do that one is to take the ECM off, cruise control servo off and pull the battery out. No way anyone else there will know that trick. For things like that, NFW would I want to do it if I was working at the store that you came to so I can't expect them to do it. Where was the battery in your Lacross?
Old Jan 8, 2022 | 04:00 PM
Mad*Max's Avatar
Mad*Max
it is under the hood but has one of those Borg lookalike contraptions sittng on the battery, having said that i was able to change myself at home recently and I am not a good mechanic
