Splitter met curb
Old Jan 16, 2022 | 11:36 AM
slburgie's Avatar
slburgie
Default Splitter met curb
Even with being careful, using forward cameras and looking before turning,,,,my front splitter found a curb and emitted that awful sound. How big of a job is the replacement. Can if be done at home in the garage with the front up on ramps? Hate to take it to the dealership$$$$ already ordered the replacement.
Old Jan 16, 2022 | 11:43 AM
17GSHeritage's Avatar
17GSHeritage
Overall not bad at all. Just some screws and some rivets to drill out. Yes you should be able to do with the front on ramps.
Old Jan 16, 2022 | 11:54 AM
Gixxerman's Avatar
Gixxerman
Moderator
St. Jude Donor '18 thru '25
as stated above race ramps would help greatly .. and possibly a right angle drill as well depending on how much clearance you have to work with.
Old Jan 16, 2022 | 03:14 PM
DALE#3's Avatar
DALE#3
I would go with a cheap but good looking replacement.Cause well,you know and unfortunately found out.
Old Jan 16, 2022 | 03:15 PM
JUICEBOX's Avatar
JUICEBOX
Veteran: Marine Corps
Takes about an hour to R/R
Old Jan 16, 2022 | 03:55 PM
NortonCO's Avatar
NortonCO
x4.
@Pineapple provides a good summary of options in this post. FWIW, I went with a combination of parts from @ACS Composite and @C7 Carbon, and I remain happy with both.
I attached the upgraded splitter with a combination of the original screws/bolts,
plastic push pins plastic push pins
(instead of rivets), and
3M tape 3M tape
. Still holding firm after over 2K miles and speeds up to a little over 140MPH.
Old Jan 16, 2022 | 04:30 PM
hisvett's Avatar
hisvett
St. Jude Donor '14-'15
No need going to the dealer and paying the big $$$ for shop labor; if a friend doesn't have ramps, make up your own out of 2X6 boards, two high with beveled ends to drive up on.....or go to Harbor or Walmart and buy metal ones. Then you'll have some for oil changes or whatever else comes along. After market like C7 Carbon Splitters are put on using factory airdam screws; use your electric drill and 7MM (I think) socket to remove and replace your splitter. Depending on how hard you hit the curb, you may have cracked the undertray that the splitter is attached to or possibly cracked some body paint just above the splitter.....ask me how I know!
Good luck, it really is an easy fix. Just take your time, use a friend, more hands make the job much easier.
Old Jan 16, 2022 | 04:50 PM
hisvett's Avatar
hisvett
Just found this C7 Carbon Sale; http://www.jwmotorsportsllc.com/JWM-...ber_p_347.html
Old Jan 16, 2022 | 09:55 PM
I agree - that is how I put my poverty splitter on my car.
Old Jan 17, 2022 | 08:37 AM
GSCE#456's Avatar
GSCE#456
Easy removal and install. Only suggestion is to get someone to help hold it up until you get a few screws in to hold it even / level.
Did mine without a ramp. Just pulled to the edge of my driveway that sloped down into the grass and did the work.
I went with a cheaper EOS ZR1 splitter because they are all going to be damaged at some point. Figured better to spend $750 vs. $2k for a ACS splitter. I think it looks great and it has held up. Still looks perfect.
Old Jan 17, 2022 | 09:38 AM
stevettec7's Avatar
stevettec7
I too went with the less expensive version from Extreme Online Store after having had 3 carbon flash painted poverty splitters replaced due to damage. One by me. One by a valet. And one by the dealer’s porter.
This looks tons better than the flat black poverty splitter IMO.
Old Jan 23, 2022 | 06:16 PM
Vette E Boop's Avatar
Vette E Boop
Ouch! That’s too bad. I had a ProTEKt skid plate installed because I knew at some point, mine might get scraped.
www.protektskidplates.com
Old Jan 23, 2022 | 06:46 PM
Mayor111's Avatar
Mayor111
It's a super easy install. The "hardest" part (and by hard I mean the most time consuming) is drilling out the current rivets. Make sure you buy a replacement that doesn't require drilling...its not a part to go cheap as it will cost you headaches. Here is the under view of when I completed mine. If you need any help - just PM me and I can share my # and walk you through exactly what you need and what to do.
I wanted to factory look but wanted it to match all of the carbon flash...so I went with this... I can tell you where to get one, if this is the look you want.
To Splitter met curb
