Tire tread depth
Old Jan 21, 2022 | 09:06 PM
GN Sport user's Avatar
GN Sport user
Default Tire tread depth
Does anyone know what is the tire depth of a brand new set of Michelin Pilot Sport cup tires
Old Jan 21, 2022 | 09:25 PM
GREENKAR's Avatar
GREENKAR
Go to Michelin's web site. You just might find your answer.
Old Jan 21, 2022 | 09:36 PM
For the Z06 (2017), the front tires have a tread depth of 7.4/32”. The rear tires are listed at 7.8/32”.
Old Jan 22, 2022 | 05:15 AM
DALE#3's Avatar
DALE#3
You ain't getting much.Dam,Inflation
Old Jan 22, 2022 | 09:28 AM
EVRGRN's Avatar
EVRGRN
^^Those tires have had that tread depth since they were released years ago.
Yes, it's comparatively low though and other options have greater tread depths.
Old Jan 22, 2022 | 03:44 PM
iclick's Avatar
iclick
My 2017 GS had 7.2/32" in the outer and middle large groove of both front and rear tires (non-Cup2), but 6.7/32" in the inner groove. Being less than spec and the discrepancy in the inner groove surprised me so I checked another new GS at a local dealership and it was the same. So don't freak out if you see less depth on the inner groove and blame wheel alignment, that is unless its >0.5/32".
Old Jan 22, 2022 | 11:51 PM
Sleazy Rider's Avatar
Sleazy Rider
Veteran: Marine Corps
tire rack states that the tread depth is 5.9/32 for the fronts and 5.7/32 for the rears.
Specs for Selected Tire
This front/rear set fits your 2017 Chevrolet Corvette Grand Sport Coupe.
SIZE UTQG MAX.
LOAD
MAX. INFLATION PRESSURE TREAD DEPTH TIRE WEIGHT RIM WIDTH RANGE MEAS. RIM WIDTH SECT. WIDTH TREAD WIDTH OVERALL DIAM. REVS. PER MILE COUNTRY OF
ORIGIN*
P285/30ZR19
(94Y) SL
Run Flat
Front
180 AA A 1,477 lbs 51 psi 5.9/32" 29 lbs 9.5-10.5" 10" 11.4" 11.2" 25.8" 807 US
P335/25ZR20 (99Y) SL
Run Flat
Rear
180 AA A 1,709 lbs 51 psi 5.7/32" 32 lbs 11.5-12.5" 12" 13.5" 13" 26.6" 782 US
To Tire tread depth
