Question New Vette Owner
Old Jan 23, 2022 | 11:58 AM
Eray78's Avatar
Eray78
Navigator
Default Question New Vette Owner
Thanks for the add 1st off. I'm a new vette owner of a 16 Z06. Its has 37k on it. And I'm trying to google and research about this rev limiter. And the only thing Im finding is qbout cars with 500 or less miles. I've added a picture for reference. Does the ring on the outside of the tach only show when the engine or tranny is cold. Because I notice it randomly comes and goes(as far as the yellow and orange areas). Any information would be useful and appreciated.
Old Jan 23, 2022 | 12:20 PM
joemessman's Avatar
joemessman
It should only come on when the engine isn't warmed up to proper temp. What does your engine temp show? After you drive it long enough to warm up and the rev limiter disappears and then comes back on check the engine temp. May be something wrong with the thermostat.
Old Jan 23, 2022 | 12:52 PM
duckvett's Avatar
duckvett
2023 C7 of the Year Winner - Unmodified
2018 C6 of Year Winner
^^^ Agreed! It comes on with each cold start and gradually goes away as the engine warms. You shouldn't see this again until the next cold start.
Old Jan 23, 2022 | 01:53 PM
rightrudder's Avatar
rightrudder
I always plan my morning coffee-run drives so I'm sitting in a left turn pocket at the light, typically for a couple minutes. A nice way to let the temps come up.
Old Jan 23, 2022 | 01:59 PM
When doing a cold start, the ring will show up. As the engine warms, you will notice that the yellow bars will slowly decrease to the right and when the engine gets warm enough, the ring will disappear.
Old Jan 23, 2022 | 02:25 PM
Eray78's Avatar
Eray78
Navigator
Thank you all. Yes it's been cold down south here in the 30s. And the eng temps been sitting about 150-160 daily. So that could be it. Sorry just new to this area.
Thank you much
Old Jan 23, 2022 | 03:26 PM
Maxpowers's Avatar
Maxpowers
Dont be sorry....this forum is all about asking questions. I suggest you set aside an hour to read the manual. Lotsa info in there. Welcome.
Old Jan 23, 2022 | 05:52 PM
Guard Dad's Avatar
Guard Dad
The manual is hardly a page turner but there are lots of valuable nuggets of information buried in the text. There are lots of ins and outs to the dash displays that you can play around with like trans temp, horsepower, tire temp, tire pressure, G meter and not to mention programming the exhaust, suspension and steering. Don’t miss out on the fun stuff, the manual is your friend.
Old Jan 23, 2022 | 06:11 PM
Warpdrv's Avatar
Warpdrv
Banned Scam/Spammer
There are also plenty of youtube videos out there for the stuff mentioned above.....
I didn't even drive my new to me vette yet - really, winter here, but I have watched **** tons of videos that go well into detail about the hidden adjustments for the C7's.... https://www.youtube.com/results?sear...idden+features
Old Jan 23, 2022 | 08:04 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
My understanding is that the "floating" yellow & red arcs are not a rev limiter, the driver is simply expected to obey them.
There is a real rev limiter at the fixed red line only.
The floating arcs appear to be controlled by coolant temperature. I suppose that's better than nothing, but in really cold weather the floating arcs can disappear completely when the oil temperature has barely come off the peg. I keep oil pressure and oil temperature displayed in the little pocket gauges, and don't go full throttle until the oil reaches 160'F.
Enjoy your car!
Old Jan 23, 2022 | 08:18 PM
duckvett's Avatar
duckvett
Thank you much
I want to go back to the OP saying the engine temps are running 150-160 degrees. Running temps should be in the 200-220 range. Maybe a previous owner changed to a 160 thermostat? I don't believe there is any benefit to running that low. (???)
Old Jan 23, 2022 | 08:43 PM
mdformula350's Avatar
mdformula350
well i didnt even notice that feature before. cool beans.
this car im still learning stuff over a year now.
Old Jan 23, 2022 | 10:11 PM
Gearhead Jim
St. Jude Donor '13
On our dry sump (Z51), oil temp takes a lot longer to stabilize in cold temps than coolant temp, but eventually both of them settle around 190
Old Jan 23, 2022 | 10:38 PM
Skid Row Joe's Avatar
Skid Row Joe
Engine temperature related.
Old Jan 24, 2022 | 10:48 AM
tranceporter's Avatar
tranceporter
Yup.
If you're seeing the ring come back after driving the car for an extended period of time then you probably have an issue with the thermostat. My car was taking a long time for the oil temperature to warm up and I'd notice the RPM ring coming back even after driving for 30+ minutes on the highway. I changed my thermostat (after two dealers did not find a problem) and the issue went away entirely. I no longer see the RPM ring return after the car has warmed up.
Old Jan 24, 2022 | 01:22 PM
Power Hawk's Avatar
Power Hawk
The yellow and red lines are not rev limiter lines. The yellow line means the engine is not warmed up yet and is a suggestion not to exceed engine revs past where the line shows. The red line indicates danger if revs exceed into that area. The rev limiter will actually not allow revs go to beyond a level which will cause engine damage. I have heard a couple hit the rev limiter in their Corvette, which is not a good thing.
Old Jan 24, 2022 | 04:06 PM
Bill Dearborn's Avatar
Bill Dearborn
It is also not a terrible thing to hit the actual rev limiter. Over the 6 years, I have had my C7Z I have hit the rev limiter many times when on track. It usually happens when I am coming off a slow corner onto a long straight and I have the transmission in 2nd gear and I am waiting for slower cars to move to the right and provide a point by. Even with the HUD, it is easy to hit the rev limiter as you are picking up speed while waiting for 3 or 4 cars to sort themselves out and to decide which side of the track they want to be on. Until I know what they are doing I focus on them Vs the tach.
Bill
To Question New Vette Owner
Old Jan 25, 2022 | 02:18 AM
Zimbatoo's Avatar
Zimbatoo
Originally Posted by tranceporter
Yup.
This is actually happening to me right now but had no idea what was going on, great to know that it's nothing serious.
Old Jan 25, 2022 | 04:13 AM
tranceporter
Seems like a pretty common problem. Only 4800 miles on my 2019 GS and had to do my first fix.
Old Jan 25, 2022 | 07:21 AM
Eray78's Avatar
Eray78
Navigator
Yup.
I'm looking into this as week speak. Thank you all for the input.
