Winter question!
Old Feb 26, 2022 | 02:41 PM
Apocolips's Avatar
Apocolips
Default Winter question!
The car has been in the garage for 6 weeks hooked up to a battery tender. Does it need to be started and let idle for a while? There is too much salt and gravel on the roads for a drive.
Old Feb 26, 2022 | 02:58 PM
Vette Ski's Avatar
Vette Ski
No, its best to not start it and create moisture. Wait another few weeks, month, to take it for a good run !
Rich
Old Feb 26, 2022 | 03:06 PM
zigfire66's Avatar
zigfire66
6th Gear
The quick answer is No. There are several old threads that talk about the best way to placing your Corvette into storage. Depending on the age or your Corvette will determine the best way to get it ready for hibernation. But one thing all of those post document say is once the car is put away is to just leave it. Do a search on general discussion tab of your corvette version and you'll find several threads on this topic.
Old Feb 26, 2022 | 03:09 PM
Zjoe6's Avatar
Zjoe6
I never start mine over the winter. As mentioned, introduces moisture that doesn't get boiled off in the cold engine. The battery tender is all that's needed.
Old Feb 26, 2022 | 03:19 PM
Mad*Max's Avatar
Mad*Max
I start mine every 2-3 weeks but I make sure I get the oil temp up, I also move it around a bit so that everything gets used a bit...I did that with my C6 and had no leaks etc.
Hearing and feeling the V8 is the reward for the exercise, last time I started the car it sounded like a damn explosion :-)
Old Feb 26, 2022 | 04:40 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
I've been doing the same for the last 15 winters (Nov-Mar) on each Corvette we've owned. I too make sure a combination of idling and going up/down our 50 yd driveway gets the oil to at least 175'F, usually takes 30+ minutes. Turn the steering full lock, use different gears, etc. When I do the next oil change and send in a sample for analysis, the contaminants and wear numbers are always like a summer-only oil run.
Just starting and letting it idle for a couple of minutes is probably bad, and I don't do that.
Old Feb 26, 2022 | 05:03 PM
dvilin's Avatar
dvilin
No need to do anything until you are ready to unhook the tender and take it for a nice cruise.
Old Feb 26, 2022 | 05:13 PM
Red08's Avatar
Red08
As others have said....No, it does not need to be started
Old Feb 26, 2022 | 05:44 PM
LDB's Avatar
LDB
Gearhead Jim has the proper caution. If you decide that you must start it (which most including me would say is not necessary) be certain that the oil temp is at least 170 before shut down (yes, oil temp -- the coolant temp is irrelevant). As Gearhead says, that will take quite a while if you stay in the garage or driveway. Reason for the caution is that combustion products contain water vapor, and some of those gases get past the piston rings as piston blowby, into the crankcase. When the engine and oil are cold, some of the water vapor condenses into liquid water, and that plus other components in the piston blowby make an ideal setup to form carboxylic acids. So what you accomplish with a brief startup is basically to inject some acid into your crankcase and oil. If you let the oil heat up to 170+, the water will evaporate and the carboxylic acids, with heat and without water, will break down. This same mechanism is the reason that most owner’s manuals say that if most of your trips are short (which prevents oil from getting above 170) you should change your oil more often.
Old Feb 26, 2022 | 06:21 PM
Elk's Avatar
Elk
While fully warming up the vehicle minimizes the harm, there remains no upside to starting the car while parked for the winter.
Old Feb 26, 2022 | 06:25 PM
user051728's Avatar
user051728
In 14 years of owning Corvettes I've never started them in the winter unless it was for some other reason.
I am a fan of leaving it on the ground (so suspension loaded), not in gear, and no parking brake engaged.
Old Feb 26, 2022 | 06:28 PM
Gearhead Jim
St. Jude Donor '13
I think there is some upside, particularly in exercising most of the other systems in the car. But nobody is doing long-term controlled tests to find out, so we all take our best guess.
Old Feb 26, 2022 | 07:50 PM
aklim's Avatar
aklim
To what end? If it has sat that long, another few weeks won't change anything.
Old Feb 26, 2022 | 07:57 PM
Kevin A Jones's Avatar
Kevin A Jones
Just connect it to a battery tender and put it away, no need to baby-sit a car.
Old Feb 26, 2022 | 10:54 PM
No, unless you plan to take it for a decent length drive to where everything can get up to temp and stay that way for a while, just leave it sitting in the garage hooked to a battery tender. It won’t hurt anything to let it sit a while longer.
Old Feb 26, 2022 | 11:39 PM
Skid Row Joe's Avatar
Skid Row Joe
No.
Old Feb 27, 2022 | 01:18 AM
Gixxerman's Avatar
Gixxerman
Moderator
St. Jude Donor '18 thru '25
As above have all stated that's a big NO..
To Winter question!
Old Feb 27, 2022 | 07:40 AM
449er's Avatar
449er
CF Community Team
No need to start the car until you can actually drive it
Old Feb 27, 2022 | 07:54 AM
Apocolips's Avatar
Apocolips
Thanks everyone! I guess that I am a little anxious to get out on the road. I won't take it out until the roads are clear of the chemicals/salt and sand is washed away. It will be hard though, next week the temps are supposed to be in the upper 60's!
Old Feb 27, 2022 | 09:00 AM
Vette Ski's Avatar
Vette Ski
Rich
How many more times are we gonna say wat I already said ? NO !!!
Rich
