C7 repair
Old Mar 2, 2022 | 03:43 PM
lruggley's Avatar
lruggley
8th Gear
Default C7 repair
Driving 70 MPH on interstate, 6” diameter rock came from nowhere striking the RF bumper. Impact was so severe 4 way flashers activated, both seat belts retracted, service airbags warning came on(air bags did not deploy), there was a pronounced hissing (?) noise and smoke coming from under the glove compartment. Keep the C7 under a controlled stop along the shoulder.
Questions I have:
1. Did the safety features operate properly? Believe there might be a recall that airbags not operating properly, however my VIN shows no recalls.
2. Do the repairs have to be made by a certified GM dealer?
3. Can the front clip be repaired or does it need to be replaced?
Old Mar 2, 2022 | 04:00 PM
Elk's Avatar
Elk
It sounds like everything worked as it should, any repair shop can do the work, the part will be replaced.
Old Mar 2, 2022 | 04:09 PM
TraceZ's Avatar
TraceZ
My quick assessment:
The front bumper cover will need to be replaced and the new part painted
The grill will need to be replaced
The seatbelts will need to be rebuilt
The airbag module will need to be reset
I don't have an explanation for why there would be pronounced hissing (?) noise and smoke coming from under the glove compartment.
Old Mar 2, 2022 | 04:30 PM
DALE#3's Avatar
DALE#3
Holy crap your lucky it didn't come threw the windshield.Big hit.The hissing could be a AC line or Cooling system line that wasn't to stable.Possible vibration from a hit like that made it looser to hiss?
Look along the firewall for any signs of a leak.Losing any antifreeze?
Old Mar 2, 2022 | 04:59 PM
Vette Jockey's Avatar
Vette Jockey
Roadster Madness. 😠
St. Jude Donor '13, '20-'21
Wow! I am sure glad no one got hurt! Good luck on the repair.
Old Mar 2, 2022 | 06:15 PM
Lucky indeed that the rock struck the fascia rather than the windshield. If any positive out of this, it would be a great time to upgrade to the GS/Z06 grille instead of the base grille.
Best of luck with the repair.
Old Mar 2, 2022 | 06:57 PM
Gixxerman's Avatar
Gixxerman
Moderator
St. Jude Donor '18 thru '25
Old Mar 2, 2022 | 11:17 PM
ZedConn's Avatar
ZedConn
Ugh...I bet that just ruined your whole day! So sorry this happened to you but definitely glad nobody was hurt!
Old Mar 3, 2022 | 12:18 AM
Avanti's Avatar
Avanti
Get it to a decent dealer for inspection, and contact your insurance carrier to have them take a look, as well. All the best.
Old Mar 3, 2022 | 06:24 AM
mdformula350's Avatar
mdformula350
wow hell of a rock for sure, glad your ok and no one hurt.
good luck with repairs, certainly could of been worse. would get at least 2 quotes for sure and maybe even have them put on lift to check out underneath quickly as well. certainly mention the noise and general location.
Old Mar 3, 2022 | 08:03 AM
449er's Avatar
449er
CF Community Team
Like the others stated, just be glad that you didn't get hurt....any competent body shop can fix your car
Old Mar 3, 2022 | 08:22 AM
Tinkertech's Avatar
Tinkertech
Interesting camera and where you mounted it.
I take it that this camera is for you to see the curb in front of the car?
If so, what brand and where did you purchase it?
Old Mar 3, 2022 | 10:53 AM
Maxpowers's Avatar
Maxpowers
There is an airbag recall for some C7's. Mine was updated. The impact doesnt look like the airbags should have deployed. But maybe the sensor was damaged.
Old Mar 3, 2022 | 11:32 AM
Buddhaman's Avatar
Buddhaman
That’s an option (maybe standard) on the newer C7s.
Old Mar 3, 2022 | 11:51 AM
Zjoe6's Avatar
Zjoe6
Wow it picked a good place to hit. The bumper area is one of the strongest areas of the car. Glad you're ok. Get it fixed and you'll be good to go.
Old Mar 3, 2022 | 12:27 PM
TraceZ's Avatar
TraceZ
Was anyone sitting in the passenger seat at the time of the rock damage?
Old Mar 3, 2022 | 01:26 PM
orca1946's Avatar
orca1946
Yikes!! Glad you are ok. That hissing sounds requires looking into. I like the upgrade to Z06 parts!
To C7 repair
Old Mar 3, 2022 | 04:58 PM
Bill Dearborn's Avatar
Bill Dearborn
The seat belts may not need to be replaced/rebuilt but the belt pre-tensioners (the belt receivers located on the inside of each seat) will need to be replaced although if you didn't have a passenger the passenger side pre-tensioner may be OK. They are part of the SIR and are the reason why the airbag light is on.
Any qualified body shop should be able to do the repairs. However, how long it takes may be an issue. I just had a body shop do some work on my car and they told me I was lucky I didn't need any parts. Parts lead times are killing them on every brand car they have worked on for quite a while.
Bill
Old Mar 3, 2022 | 06:50 PM
Spicy16's Avatar
Spicy16
Factory front curb camera on 2016-2019 2&3LT models.
Old Mar 3, 2022 | 06:52 PM
Spicy16's Avatar
Spicy16
I agree with the others, glad everyone is okay and you didn't panic on the roadway. I think it hit one of the best places you could hope for!
Definitely looking at nose and grille replacement. I would also recommend taking the opportunity to go with a Z06 replacement grille. They look fantastic.
Good luck!
