No Check Engine Light?
Old Mar 7, 2022 | 08:27 PM
mdanielz0sick's Avatar
mdanielz0sick
5th Gear
Default No Check Engine Light?
Just installed LT Headers and X pipe on my 2016 Z06 A8. We used all 4 O2 sensors instead of just 2. Check engine light turned on for a couple of minutes, but has then been off. Has this happened to any of you?
Old Mar 8, 2022 | 08:45 PM
Avanti's Avatar
Avanti
Can't say myself, but since no one else has replied, I'd suggest, since the light is out, to drive it. If the light returns you can check the codes with a cheapo reader and go from there. All the best.
Old Mar 8, 2022 | 09:18 PM
Dcasole's Avatar
Dcasole
The ECM only checks rear O2 Cat efficiency after so many starts . Its not if you will get CEL just when
Dave
To No Check Engine Light?
