Sorry can't hear your type of download but if it is the sound of steaks kinda sizzling on a grill?That is nothing to worry about.With the time of the sound odds are it is this?
Let me know if correct?
Maybe a lottery day,maybe not
the recording is a 9 sec video from my iPhone while in the cabin
Just downloaded to hear it.Never heard that or I can't remember any reports of it.I would feel around and try to pinpoint it's exact location that would be a start.
Any engine light?
Sounds like heat contraction after shutting off the car.
Is the noise there before starting the car? After shutting the car off?
If the noise is there all the time, you may need to disconnect the battery and see if the noise goes away.
If the noise does go away, remove fuses one at a time to fine which circuit is causing the noise.
the noise stopped once I disconnected the battery. I have not plugged it back in yet. Sounds more of a electrical issue it seems. The fuse are you referring to the front of car fuse box ? There is also one in the back trunk which is very difficult to get too
I would start with the fuse-box in the truck/rear first. I believe it has most of the interior electrical fuses. Take one out at a time to find the circuit that is causing the noise.
Good luck.
I have that when I open a door. I first thought it was a mouse, but I really think it is a relay or timer or something like that.
That is what i am kinda hoping it is as well. It is not, anything to do with engine cooling down as I went to go start car next day and sound appeared before I started vehicle.
