Soler TB and TC
Old Apr 9, 2022 | 10:37 AM
1FINE99's Avatar
1FINE99
Cruise-In IV Veteran
Cruise-In V Veteran
Default Soler TB and TC
I will be getting both this Wed. For those of you that bought both at the same time I have a question.
Which one did you program first or does it matter ?
I am thinking of programing the throttle controller first then doing the start -stop throttle body programing second .
Old Apr 9, 2022 | 11:07 AM
Elk's Avatar
Elk
It does not matter which you install first, and you can install both at the same time.
I suggest installing the throttle body first and giving the car a chance to adjust to it. Then install the throttle controller. However, one can install both at the same time, set the controller to pass through the stock GM signals, and getting the same result.
Have fun!
Old Apr 9, 2022 | 12:51 PM
1FINE99's Avatar
1FINE99
Cruise-In V Veteran
Have fun!
Thanks !
Old Apr 9, 2022 | 07:23 PM
jimmbbo's Avatar
jimmbbo
Also, in the unlikely event of a problem with one of the components, installing one at a time will isolate the faulty part.
Be ready for giggles 'n' grins when you get 'em installed!
Old Apr 9, 2022 | 09:06 PM
mdolandese's Avatar
mdolandese
Congrats on the Soler TB & TC your going to love them! I guarantee you won’t be disappointed Enjoy and be safe
Old Apr 9, 2022 | 09:55 PM
rjla67's Avatar
rjla67
You have to program the throttle body and throttle controller? I’m confused for I was thinking of getting the throttle body but it needs to be programmed?
Old Apr 9, 2022 | 10:00 PM
Elk's Avatar
Elk
No, the throttle body need not be programed. The car merely needs an opportunity to adjust itself to the change from OEM. This is easily done by disconnecting the battery to clear the ECM, and then reconnecting and driving the car.
The throttle controller needs nothing but installation.
Old Apr 9, 2022 | 10:08 PM
rjla67's Avatar
rjla67
Ah, makes sense. I just placed my order for the TC and TB and will be excited to see how they perform. Thanks for the clarification!
Old Apr 9, 2022 | 10:47 PM
Good luck with the install - you are going to love the improved response the car will show.
Old Apr 9, 2022 | 11:17 PM
jimmbbo's Avatar
jimmbbo
The TB comes with instructions for two different procedures - disconnect the battery or drive the car according to the instructions to let the TB "learn" to work on your vehicle.
When you get the TC installed, its "ludicrous" mode is well named and to avoid color coding your underwear, try it on an open road without a lot of traffic...
Old Apr 9, 2022 | 11:44 PM
1FINE99's Avatar
1FINE99
Cruise-In V Veteran
If you disconnect the battery do you lose your radio presets ?
Old Apr 10, 2022 | 12:25 AM
Elk's Avatar
Elk
No. Nothing is lost. You need only re-index the windows.
Old Apr 10, 2022 | 12:27 AM
NortonCO's Avatar
NortonCO
As others have said, there is no "programming" required for either part. There's also no need to disconnect the battery or to sequence the installs. The TC offers an OE mode which is, effectively, a pass-thru of stock signals. With that in mind, I installed both the TB and TC simultaneously. I left the TC in OE mode for (what I THINK was) a couple hundred miles, for the ECM to "learn" the TB, after which I started playing with the TC. Playing with the TC is nothing more than setting modes and levels.
Old Apr 10, 2022 | 08:43 AM
Elk's Avatar
Elk
As a side note, it is easier to pull the fuse for the ECM than disconnect the battery if you prefer.
Old Apr 11, 2022 | 03:14 AM
jimmbbo's Avatar
jimmbbo
No, but I did the learn by driving because it was easy to do, and I needed to run some errands.
Old Apr 11, 2022 | 05:58 PM
1FINE99's Avatar
1FINE99
Cruise-In V Veteran
Suppose to get them today !! Wow ,that was fast !!
Old Apr 11, 2022 | 06:16 PM
Gixxerman's Avatar
Gixxerman
Moderator
St. Jude Donor '18 thru '25
Congratz! You'll love it
To Soler TB and TC
Old Apr 11, 2022 | 10:46 PM
mtb2015's Avatar
mtb2015
Please update when all installed, and if you feel a difference. Thanks.
Old Apr 11, 2022 | 10:58 PM
rjla67's Avatar
rjla67
My order shipped today for the TC & TB. Looking forward to seeing how this combo works for I know in my Camaro SS it made a noticeable difference in eliminating the dead spot in the throttle response.
Old Apr 12, 2022 | 10:00 AM
WPGZ06's Avatar
WPGZ06
If you do the combo there is 100% change you experience a change. Guaranteed.
