✅SOLUTION‼️ Something new
Old Apr 6, 2022 | 12:05 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Default ✅SOLUTION‼️ Something new
We are trying something new in the tech sections of our forums. If you do a thread or search and see a thread that pops up in your search with "✅SOLUTION‼️" in the thread header, look there first. We are going to try and add the "✅SOLUTION‼️" to threads that do in fact answer the question posed. We also are putting the "✅SOLUTION‼️" down in the post that contains the answer.
So, you search for The TPMS sensor number for your car. If you get a search result that contains a "✅SOLUTION‼️", try that thread first and scroll down in the post to see "✅SOLUTION‼️" in a post/reply for your answer.
This will be a slow process for us to edit the threads with the "✅SOLUTION‼️". If you see a thread that contains a solution to the question or subject in the thread header, let us know of the existence of the thread and the post with the answer. (This might make me resign as a mod as I fear we will get swamped.)
This might end up as a lot of "✅SOLUTION‼️" on the forum. Hopefully, ya'll can try and report only one thread on a specific topic. That'd be a great help in keeping us from getting swamped with "✅SOLUTION‼️" reports.
Moderator
Old May 21, 2022 | 02:04 PM
ZMMMMM's Avatar
ZMMMMM
It's a great idea that absolutely adds value to the forum, but... the implementation obviously needs an upgrade. The OP should be able to click a checkbox in the post that contains the solution.
Here is one... https://www.corvetteforum.com/forums/c7-general-discussion/4636957-very-strange-thoughts.html#post1605158614
Old Oct 19, 2022 | 03:36 PM
jdaniels138's Avatar
jdaniels138
Veteran: Marine Corps
Sometimes you have to drawn a line in the sand and focus on doing this for all new posts going forward.
And do best effort for posts within the last x day/mounts... Or focus on the top X viewed threads...
/JD
To ✅SOLUTION‼️ Something new
