Memory seats and mirrors
Old May 15, 2022 | 09:06 AM
Wujekcity's Avatar
Wujekcity
Default Memory seats and mirrors
From what I understand, the mirror memory settings are included when you set the memory on the doors yet my mirrors keep going back to a different setting after I had my new key fob programmed. So every time I drive the car [mine is a daily driver) I have to set the mirrors. Please help ! 2017 GS
Old May 15, 2022 | 09:25 AM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
How many FOBs do you have?
Was your new FOB added as #3?
What FOB are you using, 1, 2 or 1, and 3?
Elmer
Old May 15, 2022 | 10:58 AM
SGM Snake's Avatar
SGM Snake
Default Mine too
2 fobs. One is put away since I am the main driver.
I have set 1 and 2 because I can’t tell if I use fob 1 or 2.
My Acura tells me which driver I am according to the fob.
mirrors rarely go to the set position. So before I go I set it manually.
Just a minor inconvenience but still not right.
Seats aren’t a biggie since they are back as far as they can.
Old May 15, 2022 | 12:05 PM
Supraman45's Avatar
Supraman45
Mirror movement (tilt) can be turned off thru center screen options. Look under settings.
Old May 15, 2022 | 12:10 PM
socal_tom's Avatar
socal_tom
Yeah I found the mirror tilt and turned it off , I like it a lot better
Old May 15, 2022 | 06:12 PM
eboggs_jkvl
Moderator emeritus
Um, are we talking OP problem or multiple issues with other folks?
Elmer
Old May 16, 2022 | 09:00 AM
Borntorun04/17's Avatar
Borntorun04/17
SMG Snake, I found when setting my mirrors and seat memory and when setting the exit feature. I found out that the seat can NOT be all the way back. Try resetting mirrors and seats but move the seat slightly forward 1/4 -1/2 a inch before trying reset.You will need to set each fob one at a time to correct memory settings. That worked for me !
I mentioning this because in your post you stated you had seat all the way back.
Old May 16, 2022 | 09:03 AM
Zjoe6's Avatar
Zjoe6
Moderator
The second post asks important questions that remain unanswered.
To Memory seats and mirrors
