Weird vent / mixer issue
Anybody ever experienced this before?
As the ambient temperature was reaching 100 degrees a few days ago, the interior of the Denali was not cooling well. I thought the AC was failing. So I checked the passenger compartment and found the vents were blowing hot air. The temperature settings for both were set to 60. I was never able to get the passenger vents to blow cold.
I shut the AC system completely down, OFF and then back ON again. This somehow reset the vents and the AC system began to control properly. Perhaps this is a common problem with all GM AC systems.
I do not and have not had this issue in my Corvette (knock on wood), but had this same issue on our old faithful minivan. So I can tell you what I learned when I diagnosed and fixed the issue (or issues) on it.
When you have two different temps coming form the AC outlets, while you have set the temp to the same value on both sides, it can be one of three issues.
1) One of the thermistors (temp sensors) have gone bad and is not giving the right temp feed back to the HVAC control module. This is not common.
2) One of the damper motors have gone bad. This is more common then #1 above but usually happens to vehicles 10+ years old and 150k or more miles. So this may not apply to you or any C7 Corvettes since not many are driven 15-20K miles per year. I had to dismantle and clean the driver side damper motor on the van. Have been working fine for the last two years now.
3) Low refrigerant in the system. This is the most common culprit. When the refrigerant is starting to go low, one side of the evaporator gets fully cooled while the other side only get partially cooled (or not cooled at all), and since the air is just pulled from one side to go to the left and the other side to go to the right, one side of the vehicle will not cool as much as the other. This starts gradually and the dampers are able to compensate for this initially, but they can do only so much and one day you get worm or hot air from one side. If the fuses are good, then get the refrigerant checked. This happened on the van about a year after I fixed the motor (at age 14, van is almost 15 years now, keeping it another year so I can teach my son driving). Found the correct refrigerant type and bought a refill can from Wally world. Been blowing cold air since. The very slow depletion of refrigerant is due to an extremely slow leak in the system and mechanics will most likely never be able to find the leak, unless the lines had a fatigue related puncture. So the solution is to re-fill and move on as opposed to replacing parts or the entire cooling system. If I remember correctly, mine was down by just a few psi in the low pressure side.
Hope this helps.
Good luck and best regards,
Vip.
There was a tech bulletin on this as well, that first recommended reflashing the HVAC controler with the latest software version. This may also be an "easy" thing to try.
If it goes full heat, most of what I have seen is it is the blend door actuator gone bad. This is a large job on the C7 as the entire dash gets disassembled to get at the actuator.
If it happens again I’ll address it. I’ve only driven the car once or twice since my original post.
