ptm function-what package?
Old Jun 1, 2022 | 07:38 PM
not08crmanymore's Avatar
not08crmanymore
Default ptm function-what package?
Hi folks. I'm looking at c7's again. Been out of a Vette for 5 years and it's bugged me every one of those 5!! lol. Am I correct that the z51 manual 2 or 3 LT will have the PTM function or is that a separate package I need to look for. Lots of automatics out here which I don't want. because if I recall they don't have PTM available or the functional air ducts on the side ?? Appreciate any info. Thanks.
Old Jun 1, 2022 | 08:01 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Any vette with the eLSD has what you're looking for.
Check for RPO code . Check for the eLSD code, G96. All Z51s came with G96.
Elmer
Old Jun 1, 2022 | 08:05 PM
not08crmanymore
What is eLSD? 15 and later would have that available correct, auto too? Thanks
Old Jun 1, 2022 | 08:11 PM
eboggs_jkvl
Moderator emeritus
Elmer
I added some info to my original answer
Old Jun 1, 2022 | 08:12 PM
not08crmanymore
Excellent!!! Thanks a million
Old Jun 2, 2022 | 07:43 AM
69 L46 4 Speed's Avatar
69 L46 4 Speed
eLSD = Electronic Limited Slip Differential
Old Jun 2, 2022 | 01:26 PM
Bill Dearborn's Avatar
Bill Dearborn
Performance Traction Management (PTM) uses Traction Control, the eLSD, and Stabiltrack to enhance traction while coming out of a corner. The Z51, Z06, GS, and ZR1 come with PTM. The base car doesn't have PTM. It doesn't matter which transmission is installed or what trim level (1, 2, or 3 LT/LZ) is installed.
From the 2019 Owner's Manual:
Bill
Old Jun 3, 2022 | 12:36 AM
Pete43's Avatar
Pete43
I have a 2014 Z51 M7 2LT and it doesn't have the PTM modes because it doesn't have Magnetic Ride Control..(No magnetic shocks) I didn't want the cost of the expensive shocks when they wear out. I have the electronic limited slip diff though. (ELSD) I do have Launch Control and No Lift Shift. Just no select able PTM modes..
Old Jun 3, 2022 | 05:06 AM
Vette Jockey's Avatar
Vette Jockey
Roadster Madness. 😠
St. Jude Donor '13, '20-'21
Another good reason to get a Z51, Z06, GS, or ZR1. I like curves!
Old Jun 3, 2022 | 01:00 PM
not08crmanymore
So it is available on 14's?Good to know. No lift shift??? What's that, no letting the clutch up?
Old Jun 3, 2022 | 01:39 PM
Pete43's Avatar
Pete43
Yes , No Lift Shift ...It lets you shift the manual while keeping the gas pedal down.
Old Jun 3, 2022 | 01:43 PM
not08crmanymore
Ahh,ok cool. Thanks
Old Jun 3, 2022 | 01:48 PM
TheRobSJ's Avatar
TheRobSJ
Not sure what this is all about but PTM is on automatics as well. Same for the side ducts.
Old Jun 3, 2022 | 02:31 PM
need-for-speed's Avatar
need-for-speed
CI 1-4-5-8-9-10 Vet
St. Jude Donor '03 thru '10, '17
Ahh,ok cool. Thanks
Note - NLS is not lifting ON THE ACCELERATOR. You still need to use the clutch.
Old Jun 3, 2022 | 06:47 PM
Avanti's Avatar
Avanti
All the extra electronic gobble-de-gook is just that must potential hassle with a used car and not needed on the street 99.99% of the time (okay, I just made up that number).
Old Jun 4, 2022 | 11:11 AM
not08crmanymore
Yea,got that.Thanks.
Old Jun 4, 2022 | 12:16 PM
Maxpowers's Avatar
Maxpowers
Welcome back. Bill did a great capture on PTM.
To ptm function-what package?
Old Jun 6, 2022 | 04:30 PM
76-Vetteman's Avatar
76-Vetteman
The 2014 with the Z51 package was in a sweet spot, insomuch that the Z51 package offered a lot, but was fairly inexpensive.
It has a lot of stuff most people don't think about.
Like the dry sump oiling system
Like the Heads-Up display
Like the lower gear train set in the M7 transmission,
Like the Performance Exhaust system
Like the External Oil cooler for the ELDS
Like the Forged Aluminum wheels 19/20 with Michelin tires that were designed for it
Like the Bembro Braking system
Like the larger sway bars
Many came magnetic ride
And so on…
Old Jun 7, 2022 | 04:37 PM
Bill Dearborn
PTM is also mechanical. The mechanical portion is probably the least reliable part of the function.
Bill
Old Jun 7, 2022 | 05:07 PM
Skid Row Joe's Avatar
Skid Row Joe
True. The basic 2014 to 2019 Stingray with 455 hp and 460 ft lbs of torque isn't controllable at WOT on the public streets and highways anyway. Certainly not within State and local speed limitations.
