Intermittent A/C
Old Jun 9, 2022 | 10:20 AM
big red one's Avatar
big red one
Default Intermittent A/C
HI Guys
This one is odd, drove for about 90 mins today and during that time realised the a/c wasn't on, all the a/c displays are working tried adjusting the temp, the fan, nothing, no air coming through the vents
I called my son who was driving it last and he said that it had happened to him as well but he forgot to mention it, it was coming on and going off at will
True enough after an hour with the windows open i felt the a/c come back on, im guessing this is a loose connection, any thoughts?
Ian
Old Jun 9, 2022 | 10:30 AM
Richard Ames's Avatar
Richard Ames
Happened to me as it starts out cold AC and then quits blowing cold air. Was caused by a failed (stuck) thermostat for the coolent and the engine heating up that causes the AC to turn off. Check your coolent tempature and it will show very low because the coolent is not getting past the thermostat.. Check engine light will not come on but it should throw a code.
c
Old Jun 9, 2022 | 11:27 AM
Maxpowers's Avatar
Maxpowers
Another CF member recently posted a bad relay caused him/her problems.
Old Jun 10, 2022 | 08:44 PM
Mad*Max's Avatar
Mad*Max
lol...sounds like my three kids
Old Jun 11, 2022 | 04:02 AM
big red one
thanks, will look into these suggestions
Old Jun 13, 2022 | 10:58 PM
Dcasole's Avatar
Dcasole
If you are saying that you had no fan at all , it's a common problem , look under the passenger side dash after removing the plastic panel held in by 3 push pins you will see a silver cover along with two wires , this is the fan power and the point of failure , unplug the fan. Clean both sides of the connector with contact cleaner then reassemble, been doing this once a year since I got my car
Dave
Old Jun 14, 2022 | 08:18 AM
Thanks for all the suggestions on how to fix this issue. Saved for future reference.
To Intermittent A/C
