C7 A8 Issues
I am not sure which flush they did. I suspect it was the PIP5405B because it was early on when the flush had just came out as the fix for the problem. A friend of mine had the problem a few months before me, before the flush fix came out, and they changed his torque converter and that solved the problem. I suspect some of the torque converters installed originally were questionable, and instead of replacing the torque converters in the cars with problems they came up with this flush fix. I don't care how they fix the problem. I just want a permanent fix that prevents the problem from reoccurring.
