Just curious what your thoughts are on 10 year old tires. 2014 C7 with original Michelin Pilot super sport zp tires with only 6500 miles and still a lot of tread. SHould i go ahead and replace with new?
I know that many are more cautious than I am, but I ran my C5 factory run flats until they were about a dozen years old before replacing them...basically until the tread was low enough, and even then I did it in pairs as the rears wore out sooner. I'll likely do the same with my C7 tires...they're only 3 years old now so plenty of time left in my mind.
Just depends on how you use your Corvette.
If visually ok, no cracking etc and just low impact around town driving you should be fine. If any degree of spirted/performance and/or long distant driving then replace them.
[QUOTE=DFWC7;1605336630]Just curious what your thoughts are on 10 year old tires. 2014 C7 with original Michelin Pilot super sport zp tires with only 6500 miles and still a lot of tread. SHould i go ahead and replace with new?[/QUOTE
I would replace them. Tires are the one thing you don't want to take chances on - you are totally reliant on those 4 patches of rubber connecting you to the road.
Oh, and since you are in DFW, I have a nice set of wheels and tires in the For Sale section. If you like chrome and wanted to upsize your wheels to 19/20...
Discount tire won't patch a tire over 7 years old. 10 years old, the tire is probably dry and the traction is waning. As Kevin said above, normal driving should be OK as long as no cracking but if you want maximum traction or go into "spirited/performance" or go on a long trip in the heat, I'd replace them. I'm on my 2nd set of "sticky" tires and my next set will be the A/S +4.
Six years maximum is the recommendation, but anything eight years or older is a no brainer. REPLACE THEM! If you are like a lot of owners around here that hardly ever drive, and drive like an old man when they do drive, keep'm.
Like ALL rubber - tire compounds get hard & start to break down over time. If your car spends 95% of its life in a garage, the tires are probably fine for a couple more years of gentle cruising. If you drive you car aggressively AT ALL, I recommend replacing them. The rubber is definitely going to be much harder than it was when it was new, whether you see cracking or not.
Directly from the Michelin website:
A few milestones and tips:
1. Keep five years in mind
After five years or more in use, your tires should be thoroughly inspected at least once per year by a professional.
2. Ten years is a maximum
If the tires haven't been replaced 10 years after their date of manufacture, as a precaution, Michelin recommends replacing them with new tires. Even if they appear to be in usable condition and have not worn down to the tread wear indicator. This applies to spare tires as well.
I bought a 14 with 5800 miles and original 2013 dated tires. I had new ones ordered thru Tire Rack before I took possession of the car. Not taking a chance on rubber that old. They do lots of damage when they come apart at speed....
Has anyone ever heard of a tire failing because it was 10 years old and in good condition? I never have although if I was driving the car hard on a track I would replace them. It also probably depends on the climate you live in as to how long they will last. I would not replace mine if they were in good shape and ten years old.
Without a doubt replace old performance tires. What's more important, a little cash or a potential failure when you're driving... shall we say "spiritedly?" All the best and stay safe.
I really appreciate everyones reply. I think I'll go ahead and replace especially since it will be the wife's daily driver if she ever goes back to the office (hopefully soon haha)
Old tires may continue to hold air and may not show signs of cracking or dry rot, but the rubber compound itself hardens over time, and after 4-5 years, will have significantly less traction than when new. Get a little too lively with the throttle or too hard/late on the brakes with old tires, you could be in for an unpleasant surprise.
Many years ago I bought an old Ferrari with 10 year old tires. Wasn't too concerned until some idiot pulled out in front of me. My tires were hard, didn't brake well, and I almost hit him. So even if you drive slowly and carefully, you never know when you'll need good tires.
